1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMS Epics build
To: TechTalk EPICS <[email protected]>
Date: Tue, 11 Sep 2007 17:47:33 -0400
I am attempting to build Epics R3.14.9 on a linux host for RTEMS-pc386 target. My RTEMS build is version 4.6.1.
The compilation aborts with the following error:
/usr/csite/pubtools/rtems/4.6.1/bin/i386-rtems-gcc --pipe -B/usr/csite/pubtools/rtems/4.6.1/i386-rtems/pc386/lib/ -specs bsp_specs -qrtems -fasm -c -DUNIX -ansi -O4 -g -Wall -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=acc.jlab.org -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=acc.jlab.org -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include ../../../src/libCom/env/envSubr.c
In file included from ../../../src/libCom/osi/osiSock.h:22,
from ../../../src/libCom/env/envSubr.c:49:
../../../include/os/RTEMS/osdSock.h:46: syntax error before "osiSocklen_t"
../../../include/os/RTEMS/osdSock.h:46: warning: type defaults to `int' in declaration of `osiSocklen_t'
../../../include/os/RTEMS/osdSock.h:46: warning: data definition has no type or storage class
In file included from ../../../src/libCom/env/envSubr.c:49:
../../../src/libCom/osi/osiSock.h:36: syntax error before "osiSocklen_t"
I noticed a tech-talk thread back in 2000 that addressed the problem of a change in the socket API. My RTEMS <sys/socket.h> does not define socklen_t . What was the final solution to this problem? Any suggestions?
Thanks in advance for any help,
Sue Witherspoon
Prev: Re: EDM Robert Horrox
Next: Re: embedded python :) Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS presentation & demo Heinrich du Toit
Next: Building asyn4-8 Szalata, Zenon M.
