1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building asyn4-8
To: "Szalata, Zenon M." <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Wed, 12 Sep 2007 16:10:31 -0500
Hi Zen,
Building testIPServerApp/src/ipSNCServer.st requires the EPICS State
Notation Language module, seq.
If you do not have the seq module installed then make sure the line
defining SNCSEQ in asyn/configure/RELEASE is commented out:
#SNCSEQ=/corvette/home/epics/devel/seq/2-0-11
If you do that, then the EPICS build system should not try to build
testIPServerApp and you won't get the error.
If you do have the seq module, then make sure the above line is
uncommented, and correctly points to your seq location.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Wednesday, September 12, 2007 12:48 PM
> To: EPICS tech-talk
> Subject: Building asyn4-8
> Building asyn 4-8 failed with the error:
> Installing dbd file ../../../dbd/testIPServer.dbd
> /usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX
>  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall
>   -g -fPIC -I. -I.. -I../../../include/os/
> Linux -I../../../include
> -I/afs/slac/g/esa/esalib/app1/epics/R3.14.9/base/include/os/Li
> nux -I/afs/slac/g
> /esa/esalib/app1/epics/R3.14.9/base/include        ../ipEchoServer.c
> nux -I/afs/slac/g
> /esa/esalib/app1/epics/R3.14.9/base/include        ../ipEchoServer2.c
> gmake[3]: *** No rule to make target `ipSNCServer.o', needed
> by `libtestIPServerSupport.a'.  Stop.
> gmake[3]: Leaving directory
> `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-
> 8/testIPServer
> App/src/O.linux-x86'
> gmake[2]: *** [install.linux-x86] Error 2
> gmake[2]: Leaving directory
> 8/testIPServer
> App/src'
> gmake[1]: *** [src.install] Error 2
> gmake[1]: Leaving directory
> 8/testIPServer
> App'
> gmake: *** [testIPServerApp.install] Error 2
> I see that there is a  file
> testIpServerApp/src/ipSNCServer.st but it somehow did not get
> properly handled.  What am doing wrong?  Am I missing something?
> Thanks in advance,
> Zen
Building asyn4-8 Szalata, Zenon M.
Prev: Building asyn4-8 Szalata, Zenon M.
Next: oscilloscope hardware selection Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
