1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: oscilloscope hardware selection
To: "Chestnut, Ronald P." <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 14 Sep 2007 17:56:27 -0700
Ronald, Gunther,
On Fri, 2007-09-14 at 15:28 -0700, Chestnut, Ronald P. wrote:
> Emmanuel,
> If "they" are using this at SLAC, I'd like to know who!
At LCLS, Dr. Gunther Haller is using an agilent Acqiris scope.
At least this is what I read in one of his presentations.
http://www-glast.slac.stanford.edu/Elec_DAQ/lcls/Reviews/Haller-Lehman-LCLS-Controls-7-07-v5.ppt
Not sure about the state of the development of epics on the
scope/digitizer.
In his presentation I read:
Up to 8 GHz waveform sampling, 1 usec record or 1-GHz, 500-usec window
At 120 Hz -> 100 Mbytes/sec
High performance to move or process data
Waveform is time-stamped via EVR
Respective beam-quality data is attached to each waveform
Agilent Acqiris 8-GHz, 10-Bit DC282 cPCI Digitizer Module
That's exactly what I want ! ;-)
> We have purchased a microIOC Scope (two channels) from COSYLAB to take a look at - only costs about $3500. If, of course, just has a Channel Access (Ethernet) connection.
Clearly not a scope in the league I am looking for.
(Bandwidth, sampling rate, memory size, etc. are out of range)
That can also explain why it is so cheap in comparison to the ones I am
looking at. I like Cosylab epics support nevertheless.
Emmanuel Mayssat
Lyncean Technologies, Inc.
650/793-0626
RE: oscilloscope hardware selection Haller, Gunther
oscilloscope hardware selection Emmanuel Mayssat
Re: oscilloscope hardware selection Emmanuel Mayssat
Prev: Re: host watchdog and PLC Emmanuel Mayssat
Next: RE: oscilloscope hardware selection Haller, Gunther
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: oscilloscope hardware selection Emmanuel Mayssat
