1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Byte Order?
To: "EPICS tech-talk" <[email protected]>
Date: Sat, 15 Sep 2007 19:01:21 -0700
I have simple softIOC which reads values from a HP34401A multimeter.  The multimeter is connected via GPIB bus to NI PCI-GPIB interface.  The IOC is built with EPICS 3.14.9, ASYN 4-8, and linux-gpib 3.2.09.
The command which reads the value is:
 {&DSET_LI,GPIBREAD,IB_Q_HIGH,"READ?","%f",0,80,NULL,0,0,NULL,NULL,NULL},
Caget shows something like: 1091779303, which is nonsence.  The value should be about 9.202.  When I change the record to stringi, then I see correct 9.2 type value.  Also in edm I see the same 1091779303 unreal number.  When I display it in hex, I see 0x41133AE7.
I also wrote a simple c program where:
  int v=0x41133ae7;
  float f;
  memdpy( &f,&v,sizeof(int));
  print( "0x%x %f\n",v,f);
This gives an output:
0x41133ae7 9.201880
All of this is on RHEL4 linux.  It seems to me that EPICS is interpreting the byte order in a way different than the c program.  But then what do I need to do to have the PV floating value be correct?  Thanks in advance,
Zen
Re: Byte Order? Eric Norum
Prev: RE: host watchdog and PLC Mark Rivers
Next: Re: Byte Order? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: host watchdog and PLC Bryce Karnaghan
