1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: OMS VME58-4S / brushless motor / servo-star3000 / motor 6.2
To: [email protected]
Date: Wed, 19 Sep 2007 09:15:21 +0200
Dear all,
In fact, I agree with you to solve problem metodically:
When I boot my system, I see motor oscillation .
after that trying then to move the motor,
I see TORQUE change in DISABLE status.
If I want move correctly, I must to set this commands:
SM("AT KP1 KD0 KI0 LP0 HN",0)
taskDelay(100)
SM("AT KO.1 RE",1)
taskDelay(100)
SM("AT AN",0)
Now Motor is working in both direction with PID : KP1 KD0 KI0 When CNEN (torque) is on/off, motor can'nt move with hands. (for handly moving a motor I must to disable a servostar) Encoder increase when motor increase. Our encoder is phased. Status update ok, I see a button.
Now I try to access a final position very fastly (with no retry) but I have a biggest error between a final position and desired position.
My setup is:
SREV= 2048 step/REV
UREV= 360 °
EGU = degrees
=> MRES = 0.17578
I put ERES & RRES with a same value
ERES=RRES=0.17578
-1/ Is it correct that ???
I use only READBACK.
-2/ How to turn off backlash  ??
   - Is it a motor with no charge ??
   - Is it a motor with no belt ??
We use a brushless motor & servo-star 300 & OMS58-4S
We would like to see one pulse more largest.
begin:vcard
fn:Jerome HOSSELET
n:HOSSELET;Jerome
org:CNRS / IPHC;Electronique / Informatique
adr:;;23 rue du loess;Strasbourg;;67000;FRANCE
email;internet:[email protected]
title:Assistant Ingenieur
tel;work:03 88 10 65 30
tel;home:03 88 xx xx xx
tel;cell:06 60 xx xx xx
note;quoted-printable:Assistant Ing=C3=A9nieur =C3=A0 l' IPHC :=0D=0A=
	- Projet CMS=0D=0A=
	- Projet SPIRAL 2
x-mozilla-html:FALSE
url:http://ireswww.in2p3.fr/
version:2.1
end:vcard
Prev: RE: Driver: Kepco BOP PS? Mark Rivers
Next: exceed Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Compiling CMLOG Error Heinrich du Toit
