1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn/VXI-11 problems
To: [email protected]
Date: Thu, 20 Sep 2007 15:02:12 +0200
On Thursday 20 September 2007 14:50, Benjamin Franksen wrote:
> On Wednesday 19 September 2007 15:36, Benjamin Franksen wrote:
> However, the IOC crashes anyway, because this is just one of many bugs.
> I'll send more debugger output soon.
Ok, now it crashes inside asyn/vxi-11 when creating the RPC client. This is
only reproducable when the ioc is started in a debugger session, probably
due to different timings. The output is attached.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
(gdb) run
Failed to read a valid object file image from memory.
[Thread debugging using libthread_db enabled]
[New Thread -1211287488 (LWP 26521)]
#!../../bin/linux-x86/SIOC6CP
# Change to top directory
cd ../..
########################################################### Set up Environment
epicsEnvSet IOC SIOC6CP
epicsEnvSet LOG_DIR log
epicsEnvSet EPICS_CA_PUT_LOG_INET 192.168.48.97
epicsEnvSet STREAM_PROTOCOL_PATH db
############################################## Register all support components
dbLoadDatabase dbd/SIOC6CP.dbd 0 0
SIOC6CP_registerRecordDeviceDriver pdbbase
############################################################ Configure drivers
# Reboot E5810
# E5810Reboot box6.acc.bessy.de E5810
# Configure asyn vxi-11 driver for GPIB box
vxi11Configure L3 tcl-101-134-Host.tcl.bessy.de 1 10 gpib0
[New Thread -1211290704 (LWP 26539)]
[New Thread -1211552848 (LWP 26540)]
[New Thread -1213912144 (LWP 26541)]
####################################################### Autosave configuration
set_requestfile_path db
set_savefile_path log/autoSaveRestore
save_restoreSet_DatedBackupFiles 1
save_restoreSet_UseStatusPVs 0
######################################################## Load record instances
dbLoadRecords db/NRVD.db
######################################################## Restore record values
#set_pass0_restoreFile <irgendwas>.sav
########################################################### Configure IOC Core
# IOC Log Server Connection  0=enabled 1=disabled
setIocLogDisable 0
# Configure Access Security
asSetFilename db/no_security.acf
#################################################################### Start IOC
iocInit
[New Thread -1211814992 (LWP 26542)]
Starting iocInit
###  EPICS IOC CORE built on Aug  9 2007
###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
[New Thread -1213203536 (LWP 26543)]
[New Thread -1214043216 (LWP 26544)]
[New Thread -1214567504 (LWP 26545)]
[New Thread -1215091792 (LWP 26546)]
2007/09/20 14:54:36.798 L3 vxi11 clientCall errno 4 clnt_stat 0
L3 port not connected
2007/09/20 14:54:36.800 L3 vxiConnectPort vxiBusStatus error initialization aborted
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1211552848 (LWP 26540)]
0xb7d46e84 in mallopt () from /lib/tls/libc.so.6
(gdb) backtrace
#0  0xb7d46e84 in mallopt () from /lib/tls/libc.so.6
#1  0xb7d45dcb in free () from /lib/tls/libc.so.6
#2  0xb7dd29c8 in xdrrec_endofrecord () from /lib/tls/libc.so.6
#3  0xb7dcb5a9 in clnttcp_create () from /lib/tls/libc.so.6
#4  0x08091e01 in vxiConnectPort (pvxiPort=0xb7dff90c, pasynUser=0xb7b005a4) at ../../asyn/vxi11/drvVxi11.c:918
#5  0x0808ec9a in vxiConnect (drvPvt=0x81e53c0, pasynUser=0x81e53c0) at ../../asyn/vxi11/drvVxi11.c:312
#6  0x0809b810 in connect (drvPvt=0x81ed940, pasynUser=0xb7b005a4) at ../../asyn/asynGpib/asynGpib.c:369
#7  0x08078ccd in asynConnectCallback (pasynUser=0xb7b005a4) at ../../asyn/asynDriver/asynManager.c:1188
#8  0x0807c48c in portThread (pport=0x81a3818) at ../../asyn/asynDriver/asynManager.c:701
#9  0x0814544c in start_routine (arg=0x81f2ca8) at ../../../src/libCom/osi/os/posix/osdThread.c:320
#10 0xb7f65b63 in start_thread () from /lib/tls/libpthread.so.0
#11 0xb7dac18a in clone () from /lib/tls/libc.so.6
(gdb)
Re: Asyn/VXI-11 problems Eric Norum
Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Benjamin Franksen
Prev: Re: Asyn/VXI-11 problems Benjamin Franksen
Next: Re: Asyn/VXI-11 problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
