On Friday 21 September 2007 17:03, Eric Norum wrote:
> On Sep 21, 2007, at 9:52 AM, Andrew Johnson wrote:
> > Eric Norum wrote:
> >>> which leads to pseudo errors; errno should be checked only if the
> >>> return
> >>> value is abnormal. It should be just
> >>> if(stat!=RPC_SUCCESS) {
> >>> /* error handling */
> >> Both the places where this code appears are preceded by
> >> assignments of 0 to errno. The fact that this was done makes me
> >> think that the code was placed there for a reason. There appear
> >> to be several substandard versions of RPC libraries out there.
> > That may be true (I have no knowledge), but on vxWorks at least
> > what Ben says is right — if you haven't been handed an error return
> > status you should assume that any value placed in errno has been
> > handled internally by the routine you called. I believe that older
> > versions of auto-save/ restore suffered from the same
> > misapprehension and generated bogus error messages as a result, but
> > I think Tim Mooney has cleaned them all up now.
> The code in question was added by Marty Kraimer -- there's nothing in
> the CVS log to suggest why, though.
> I'm leaning towards doing as Andrew and Benjamin suggest, but I still
> have this niggling feeling that the extra check must have been put
> there for a reason.
What about the following procedure: the extra check gets disabled (#if
0...#endif) and some comment is added. In case it turns out it is still
needed for some broken RPC implementation it gets re-added conditionally,
i.e. only for the target platform where the kludge is necessary.
Cheers
Ben
- Asyn/VXI-11 problems Benjamin Franksen
- Re: Asyn/VXI-11 problems Andrew Johnson
- Re: Asyn/VXI-11 problems Eric Norum
Re: Asyn/VXI-11 problems Benjamin Franksen
Learning EDM Szalata, Zenon M.
<2007>
2025
2026
<2007>
2025
2026
