1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: exceed
To: EPICS tech-talk <[email protected]>
Date: Tue, 25 Sep 2007 08:22:23 +0200
This solved the problem!!
Jippee :D
Zhan Zhang wrote:
I checked my other workstations, and they are using the file with
the same date as yours. So it doesn't seem to be the key issue. The 2004
one should work. I attached my file dated 2005, anyway.
Based on my very limited knowledge about the EPICS, the last thing I
can suspect is the environmental varialbe setting. I am not using
AUTOEXEC.bat. I assume that only works for the DOS shell. I did a test on
my computer: I removed my setting of XKEYSYMDB from "Start-->Settings-->Control
panel-->system-->advanced-->Environmental Variables-->system variables".
Next I add <<set XKEYSYMDB="C:\Program Files\EPICS WIN32
Extensions\XKeySymDB">> to autoexec.bat. I excuted the batch file and I can
see in the dos shell--
echo %XKEYSYMDB%
C:\Program Files\EPICS WIN32 Extensions\XKeySymDB
However, when I started the xserver or xming, my keyboard has no
response, although the mouse is fine, just like having a bad XkeySymDB file.
Putting the environmental variable back into where it used to be, things
worked again. That is the last thing I can think of trying. If this is not
working, the alternatives people suggested seems the way to go. Have a nice weekend!
Zhan
PS: I assume there is no 'end of line' issue (windows or linux format) for
this file. I remember that gave me a lot trouble in other places. But I
don't recall doing anything for this file--this is a windows file.
Zhan Zhang, Ph.D
Argonne National Laboratory
X-ray Science Division, Bldg 438, D005
9700 S. Cass Ave. Argonne, IL 60439
Tel: (630) 252-0863
Email: [email protected]
-----Original Message-----
From: Heinrich du Toit [mailto:[email protected]] Sent: Friday, September 21, 2007 12:03 AM
To: [email protected]
Subject: RE: exceed
The date is 2004-11-11 - from X-ming. It's now in Program Files/EPICS WIN32 Extensions
my AUTOEXEC.BAT contains:
set DISPLAY=localhost:0
set XKEYSYMDB="C:\Program Files\EPICS WIN32 Extensions\XKeySymDB"
I've tried setting these in a command prompt also.
Maybe you can email me your 2005 dated file?
Apart from that I simply don't know what to do anymore.
On Thu, 2007-09-20 at 09:38 -0500, Zhan Zhang wrote:
Oh, that's unfortunate.
What's the date of the file you are using now?
I have one dated 2000, which works for my laptop (a
3-year-old Dell) but not
my desktoop (a 1-year-old HP). On my desktop, I have to
use the file dated
2005. I kind of remember it was from X-ming. But I don't
have X-ming on my
desktop.  Rather I found it in Cgywin/usr/X11R6/lib/X11.
Also, just to double check, what's the setting for the environmental
variable XKEYSYMDB?
Zhan
Zhan Zhang, Ph.D
9700 S. Cass Ave.
Argonne, IL 60439
Tel: (630) 252-0863
Sent: Thursday, September 20, 2007 6:56 AM
Subject: Re: exceed
I've installed both Xming and X-Win32(5.4) and I've copied
the XKeysymDB file from Xming into EPICS WIN32 Extensions.
No luck.
Keyboard still not working in neither on of them.
Zhan Zhang wrote:
To solve the 'keyboard not responding' problem, replace the
file 'XKeysymDB'
in the 'EPICS WIN32 Extensions' directory with a newer
version one. The
one comes with the 'EPICS WIN32 Extensions' is too old.
Xming should
have a working one you can use.
Zhan
Zhan Zhang, Ph.D
9700 S. Cass Ave.
Argonne, IL 60439
Tel: (630) 252-0863
From: [email protected] [mailto:[email protected]] On Behalf Of
Heinrich du Toit
Sent: Wednesday, September 19, 2007 4:03 AM
To: EPICS tech-talk
Subject: exceed
How do I get exceed? (For Win32 extensions)
Xming doesn't work - keyboard not responding.
X-win32 doesn't work - keyboard not responding.
Prev: Re: Learning EDM Tim Mooney
Next: adl2edl conversion and ascii input ioc Umashankar Panda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: exceed David Kline
Next: confusion with config dir in base Heinrich du Toit
