1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: same PV on multiple IOC's - side effect
To: Jeff Hill <[email protected]>
Cc: "'TechTalk EPICS'" <[email protected]>
Date: Thu, 27 Sep 2007 14:32:41 -0700
On Thu, 2007-09-27 at 10:42 -0600, Jeff Hill wrote:
> It's a bit more complicated when more than one port is in use to make
> certain that the client sees all of the server beacons because the CA
> repeater configuration is more complex.
Great to read that because that's exactly one of the problem I have.
It works, but I don't believe my applications are getting the beacon.
Can you be more specific about the repeater configuration?
E
same PV on multiple IOC's - side effect Heinrich du Toit
Re: same PV on multiple IOC's - side effect Andrew Johnson
Re: same PV on multiple IOC's - side effect Emmanuel Mayssat
RE: same PV on multiple IOC's - side effect Jeff Hill
Prev: RE: Learning EDM Denison, PN (Peter)
Next: CA inside IOC - shutdown problem Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: same PV on multiple IOC's - side effect Jeff Hill
Next: Question about CA and optimization Heinrich du Toit
