If an output value can change due to reasons other than the output record itself then I think you need to use an input record to provide a readback of the actual value.
From: [email protected] on behalf of Heinrich du Toit
Sent: Fri 10/5/2007 7:06 AM
To: TechTalk EPICS
Subject: longout record reading?
Hallo
Ok I'm writing an asyn driver.
There is a certain option that is connected to a PV via a asynInt32
interface.
Both reading and writing of the option is allowed.
Now I can have a longout record to write to this option which is fine.
The problem is that sometimes the option changes because of something
else.
How can I force the longout record to read again?
Or is the only solution to have another longin record that will read the
value and then respond to I/O Intr from the driver?
Or can I somehow just use longout?
-Heinrich
- longout record reading? Heinrich du Toit
RE: asyn Array interrupts Mark Rivers
<2007>
2025
2026
PV aliases Lecorche Eric
<2007>
2025
2026
