1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: fedora core 7 medm (was >> Re: MEDM compile - update :)
To: Heinrich du Toit <[email protected]>
Cc: [email protected]
Date: Sun, 14 Oct 2007 05:19:21 +0200 (CEST)
Heinrich du Toit wrote:
> Recently libmotif-dev has been replaced with lesstif2-dev
> (under ubuntu anyways)
> therefore...
> in the file medm/xc/Matrix.c there is a line (44 about):
> /* Internal Motif functions not defined in header files */
> void _XmDrawShadow();
> Well under ubuntu we used to have libmotif-dev package for which this
> was needed.
> This has been replaced with lesstif2-dev
> Now the line is no longer needed.
> Infact it gives a compile error if it is there
> Further:
> in medm/xc/WheelSwitch.c:
> line 232:
> Widget _XmGetTabGroup();
> Change this to:
> /*Widget _XmGetTabGroup();*/
> #define _XmGetTabGroup XmGetTabGroup
> As XmGetTabGroup is defined now!
> I'm still getting these warnings inside xc folder compile:
> gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall -D_X86_
> -Dlinux -fPIC -D_REENTRANT  -DUNIX -D_BSD_SOURCE -I. -I..
> -I/usr/X11R6/include -I/usr/X11R6/include/X11
> -I../../../../include/os/Linux -I../../../../include
> -I/epics/base/include/os/Linux -I/epics/base/include
> -c   ../WheelSwitch.c
> ../WheelSwitch.c: In function âInitializeâ:
> ../WheelSwitch.c:687: warning: passing argument 1 of
> â_XmGetFocusPolicyâ
> from incompatible pointer type
> ../WheelSwitch.c: In function âbtn1DownProcâ:
> ../WheelSwitch.c:2831: warning: passing argument 1 of
> â_XmDispatchGadgetInputâ from incompatible pointer type
> ../WheelSwitch.c: In function âenterWindowProcâ:
> ../WheelSwitch.c:3040: warning: passing argument 1 of
> â_XmGetFocusPolicyâ from incompatible pointer type
> ../WheelSwitch.c: In function âleaveWindowProcâ:
> ../WheelSwitch.c:3066: warning: passing argument 1 of
> But medm compiles and seems to work :)
Using your instruction the medm compile but when starts:
 Trying default (fixed) instead
MEDM Version 3.1.2.1: Loading aliased fonts.................
SIGSEGV
Aborted
then crash. I'm using openmotif-2.3.0-0 ..fc7.ccmra.i386.rpm
and lesstif-devel-0.95-0-20.fc7.i386.rpm
Reading old emails about this (to fc6) I've removed lesstif and install
openmotif-devel-2....7.cmra.i386.rpm ; in this case it didn't compile:
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I..
-I/opt/epics/modules/asyn4-8/include/os/Linux
-I/opt/epics/base-3.14.9/include/os/Linux
-I/opt/epics/base-3.14.9/include -I/usr/include -I/usr/include/X11
../Caption.c
../Caption.c:30:20: error: Xm/XmP.h: No such file or directory
../Caption.c:33:22: error: Xm/Label.h: No such file or directory
In file included from ../CaptionP.h:36,
                 from ../Caption.c:34:
../Caption.h:36:19: error: Xm/Xm.h: No such file or directory
In file included from ../Caption.h:37,
/usr/include/X11/Core.h:58: error: expected â=â, â,â, â;â, âasmâ or
â__attribute__â before âWidgetClassâ
what is wrong?
Mauro.
Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Heinrich du Toit
Prev: Re: vxWorks network problem on MVME2700 Maren Purves
Next: fedora core 7 medm (was >> Re: MEDM compile - update :) Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
Next: Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Heinrich du Toit
