Hi Zen,
I just looked at the devGpib documentation, and I don't see a way to initialize an output record to the current state of the device.
You might want to look at the Steam Device instead (http://epics.web.psi.ch/software/streamdevice/doc/).
It can definitely do what you want, and it may be simpler than devGpib.
>From the Stream Device documentation:
@init
Not really an exception but formally specified in the same syntax.
This handler is called from iocInit during record initialization.
It can be used to initialize an output record with a value read from the device.
Sent: Fri 10/19/2007 8:21 PM
To: Szalata, Zenon M.; EPICS tech-talk
Subject: RE: Initial Value
I am not familiar with the devGpib device support that you are using. I was making a general point that EPICS output records typically do a read during iocInit to come up with the current state of the device. I assume it is possible to do this with devGpib but I don't know how. Eric Norum is probably the person to ask.
Sent: Fri 10/19/2007 6:38 PM
To: Mark Rivers; EPICS tech-talk
I don't understand. You seem to be implying that the mbbo record should come up in a state which corresponds to the state of the instrument. That is not what happens in my case. This is my record:
record( mbbo,"$(P)$(R)WFunc"){
field( DESC, "set function")
field( DTYP, "ag33220")
field( OUT, "#L$(L) A$(A) @4")
Am I missing some field in this? The gpibCmd is:
{&DSET_MBBO,GPIBEFASTO,IB_Q_HIGH,0,0,0,32,0,0,0,fcmds,&func,0}
Where:
static char* funcList[]={"SIN","SQU","TRI","RAMP","NOISE","DC","USER",0};
static unsigned long funcVal[]={0,1,2,3,4,5,6,7};
static struct devGpibNames func={7,funcList,funcVal,2};
static char *(fcmds[])={"APPL:SIN","APPL:SQU","APPL:TRI","APPL:RAMP",
"APPL:NOISE","APPL:DC","APPL:USER",NULL};
Thanks for helping,
Zen
-----Original Message-----
Sent: Friday, October 19, 2007 3:27 PM
Yes, the device support for the mbbo record should do an initial read of the device to get the value when the IOC boots.
You can see an example in the generic asyn device support for the mbbo record in asyn/devEpics/devAsynInt32.c
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Friday, October 19, 2007 5:24 PM
> To: EPICS tech-talk
> Subject: Initial Value
> An Agilent 33220A Wave Form Generator is attached to ICS8065
> Ethernet-GPIB controller. I am designing a soft IOC using EPICS
> 3.14.9 and asyn 4-8. I have setup mbbo type record to control the
> instrument function, which can have one of 7 values. In edm I have a
> choice button connected to this record. I can chose the function by
> clicking on one of the choices. When the instrument is in a function
> which corresponds to any but the first choice and the IOC is
> restarted, the record comes up with some initial values consistent
> with the first choice. Hence, the instrument and the IOC disagree on
> the function.
> Is there a simple way to initialize the mbbo record when the IOC is
> starting up so that it reflects the function selected in the
> instrument? Thanks, Zen
- RE: Initial Value Szalata, Zenon M.
- Initial Value Szalata, Zenon M.
- RE: Initial Value Mark Rivers
<2007>
2025
2026
<2007>
2025
2026
