1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM screens not updating on Linux
Cc: EPICS Techtalk <[email protected]>
Date: Thu, 25 Oct 2007 14:47:34 -0400
Andrew Johnson wrote:
Brian Bevins wrote:
Duh. I forgot to include that we have EDM 1-10-2 linked against EPICS 3.13.2.0.
That's likely to be at least contributing towards the problem, and it certainly isn't going to help you find someone willing to help you debug it. I recommend installing R3.14.9 and using that for building your host tools (or at least for EDM). You do *not* have to use the same version of Base for your CA clients that your IOCs are running on.
I don't expect anyone to help me debug problems with obsolete versions. If nobody has any idea why this is happening then updating everything is the next logical step, but it's going to be a significant effort because we have not yet built any production host tools against any 3.14 version of EPICS. The version of 3.13 we've been using for years has shown no such problems on HP and no other tool is failing on RHEL.
I was hoping to find some similar enough reports to make me optimistic that the effort would solve the problem. I couldn't find any on tech-talk or the EDM website, so I thought it prudent to ask before embarking on a long campaign of "let's update everything and hope the problem goes away (and hope we don't get any new ones)". I'd hate to have done all that and then get told "Silly programmer. All you had to do was enable option xyz...."
So far, in under two hours, I have four replies that all say essentially that 3.13 might be an issue. (My thanks to you, Pam, John, and Jeff.) Let the updates begin!
Jeff Notes:
Note that Mantis bug entry 291 documents some Linux compiler issues we are
encountering with R3.14.9 that don't occur with R3.14.8.
So I may try R3.14.8 first.
--Brian
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
     "Progress, far from consisting in change,
      depends on retentiveness. Those who cannot
      remember the past are condemned to repeat it."
                                         -- George Santayana
EDM screens not updating on Linux Brian Bevins
Re: EDM screens not updating on Linux Brian Bevins
Re: EDM screens not updating on Linux Andrew Johnson
Prev: RE: EDM screens not updating on Linux Jeff Hill
Next: RE: Stream device Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM screens not updating on Linux Andrew Johnson
Next: RE: EDM screens not updating on Linux Jeff Hill
