1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is there any chance that I can change SCAN parameter dynamically?
To: Zhichu Chen <[email protected]>
Cc: [email protected]
Date: Wed, 31 Oct 2007 08:57:57 -0500
Chen -
Yes, you can change the SCAN value dynamically.  Options would include:
  - Place a menu widget on your EDM screen assigned to the <fanoutRecord>.SCAN field and have the user interactively set it to the optimum value
  - Add a calcout record in your IOC database that calculates the optimum value (based on your description) and write this value to <fanoutRecord>.SCAN.
Have fun -
   Ned
On Oct 31, 2007, at 8:50 AM, Zhichu Chen wrote:
Hi all,
It's an interesting story. I've written an EPICS program and gotten it run on an oscilloscope partly successfully and used EDM to get waveforms and set parameters through CA.
What I mean by "partly" is, I used a fanout record to get waveforms from four channels and set it scan periodically, say "1 second," and it works fine unless the time scale is bigger than 0.02---0.02 is fine and 0.05 will make the oscilloscope stun until I set the time scale back to less than 0.05.
Finally, I figure out and set the SCAN field of the fanout record to "5 second" and it works again. So I guess, since time scale is 1/10 of the whole waveform---whose unit is "second"---and there're four waveforms I registered. So it will take 40*timescale to get all I want because I've told that my product---DPO7054---used only one probe for all four channels. Before I get the waveform, the buffer is locked and will never refresh in my case.
I know I can set SCAN to a very big number but, when the time scale is small, I think it's not efficient then. I'm just wondering whether I could use another record to control it, or something alternative.
Thanks for any input.
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
Re: Is there any chance that I can change SCAN parameter dynamically? Maren Purves
Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
Prev: Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
Next: Re: Is there any chance that I can change SCAN parameter dynamically? Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Is there any chance that I can change SCAN parameter dynamically? Maren Purves
