I am trying iocConsole which was downloaded from http://www.slac.stanford.edu/comp/unix/package/epics/extensions/iocConsole/. while I met some problems. If I ran the command" iocConsole ioc1"(ioc1 is defined in screenioc file), I got following messages: iocScreen: iocScreenStart.pl /home/geyang/epicsApp2/iocBoot/iocbbb/epicsApp2.sh sioc ioc2 0 command failed: -1 at /usr/local/epics/extensions/bin/linux-x86/iocScreen.pl line 78. line 78 in iocScreen.pl is like this: die "command failed: $?" unless $status ==0; After I modified iocScreen.pl to change iocScreenStart's path as this: $iocScreenStart= "/usr/local/epics/extensions/bin/linux-x86/iocScreenStart.pl"; iocConsole can go down and got following messages: iocScreen: /usr/local/epics/extensions/bin/linux-x86/iocScreenStart.pl /home/geyang/epicsApp2/iocBoot/iocbbb/epicsApp2.sh sioc ioc2 0 cd .;umask 000;/usr/bin/screen -d -m -S ioc2 -t ioc2 siocStart.pl /home/geyang/epicsApp2/iocBoot/iocbbb/epicsApp2.sh st.cmd ioc2 0 screen -list ioc2: No Sockets found in /var/run/screen/S-root. Timeout waiting for Multiuser session /home/geyang/epicsApp2/iocBoot/iocbbb/epicsApp2.sh st.cmd ioc2 0 command failed: 65280 at /usr/local/epics/extensions/bin/linux-x86/iocScreen.pl line 78. Connection to 10.10.18.55 closed. Can anybody gives me some suggestions? thanks a lot in advance. Best wishes Geyang 2007/11/1
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
