1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: lexical analyzer for .db?
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 02 Nov 2007 08:22:22 +0900
Andrew Johnson wrote:
> Heinrich du Toit wrote:
>> Is there 'n lexical analyzer for .db files?
>> I guess there must be something in epics BASE somewhere?
>> But is it written in something like flex that can easily be
>> extended/used or is it some custom code nightmare?
> The IOC's parser is written in flex and antelope (BSD-licensed versions
> of lex and yacc), the code for which you can find in base/src/dbStatic.
>  Note that you need to parse a DBD file (to define the record types,
> fields, menu selections etc.) before you can completely understand a DB
> file.
> However rather than directly grabbing and trying to use our lex and yacc
> files I would strongly recommend that you make use of the dbStaticLib
> library API which permits you to load, manipulate and save DBD and DB
> files; if you stick with the dbStatic API (documented in Chapter 14 of
> the EPICS IOC Application Developer's Guide) you're more protected
> against future changes to the syntax of the DB and DBD files.
I agree with Andrew's comment.
> It is also relatively easy to write a DB file parser in modern scripting
> languages such as Perl and Python, but it is also easy to omit some
> obscure pieces of the syntax.  You should be aware that future major
> releases of Base will probably replace the 'C' dbStatic library with
> tools written in Perl (which will have a similar Perl library for
> manipulating the underlying data).
I wrote a simple SWIG interface module for Python.
It bridges dbStaticLib and Python. And add some python code to access to
the database easier.
You can find it at:
http://www-acc.kek.jp/EPICS_Gr/products.html
> HTH,
> - Andrew
Noboru Yamamoto
J-pARC control group/EPICS group
J-PARC Center/KEK, JAPAN
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5209
tel;fax:+81-29-879-6130
x-mozilla-html:FALSE
version:2.1
end:vcard
lexical analyzer for .db? Heinrich du Toit
Re: lexical analyzer for .db? Andrew Johnson
Prev: RE: webca compile on win32 Purcell, J. David
Next: Re: lexical analyzer for .db? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: lexical analyzer for .db? Andrew Johnson
