1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: lexical analyzer for .db?
To: Heinrich du Toit <[email protected]>
Cc: [email protected]
Date: Fri, 2 Nov 2007 08:30:16 -0500
On Nov 2, 2007, at 2:05 AM, Heinrich du Toit wrote:
O let me explain.
I want to make some sort of .db file pre-processor that can do some
modifications. Mainly macro expansion type stuff.
And this I want to use so that some rule stuff can be written in Macro's
and not in long complex records and hopefully make it easier to maintain
and understand and change. And then maybe also handle some other stuff
with the pre-processor to keep thing consistently linked ect... making
it more reliable and less prone to human error. Plus the person working
with it might not fully understand all the internal stuff of 'n db.
I'm going to assume that you're aware of the dbLoadTemplate() facilties
of the IOC, and I'd be interested to hear what you need beyond what that
already provides. I want to try and stop you from reinventing the wheel
unnecessarily, but I'm not saying that what we have is comprehensive.
You should also be aware of the EPICS Extension MSI (Macro Substitution
and Include) which implements dbLoadTemplate() expansion on a host
machine and may speed up IOC boot time if you have lots of templates and
macros to instantiate.
Actually no - somehow I missed the whole LoadTemplate thing!!!
Wonder how that happen - guess you shouldn't assume things :)
Anyways I went through the documentation and it certainly will do 90% of
what I wanted to do - And no I don't want to reinvent the wheel.
The only thing I think that it doesn't do directly that I would've liked
as sort of writing extra records automatically.
Let me explain:
You have an input record (or more than one)
Then you write some calc and calcout records to do things on that input
record.
Now It would be nice if this thing created the fanout things by itself
so that all the calc and calcout stuff executes after the input
record(s)
Or is there a better way?
You may be able to eliminate the fanout records by careful design of forward links and/or input link flags (PP, CP, etc).
For example, if the input record's forward link field referenced the calc record and the calc record's forward link field referenced the calcout record, all would process each time the input record processed ... without a fanout.
For more flexibility, records can also be processed if an input PV changes by using the .CP flag of the link. In other words, if your calcout record had an input link such as INPA = "some_AI_record.VAL CP NMS" then anytime the value of some_AI_record.VAL changed the calcout record would be processed (no fanout required). CAUTION: This uses channel access so the records process at a much lower priority. Sometimes, cleverness can come back to haunt you.
Another example of what I want: So firstly we have all these input records. Then from them we have some calc and calcout records that outputs some values that are meant to control the outputs records. Then we have the output records.
The problem is that multiple calc records and calcout records is meant
for the same outputs record.
So this means that each rule must have a priority.
And then we possible want some combination of sel and calcout rules that
will select the correct records output.
You should read and understand about Scan Disable (SDIS). The processing of records can be controlled (and therefore given priority) by clever use of this field and a calc record that calculates "the priority".
Then there is also the Simulation fields for output records (SIML) which can be used to control where there output record actually writes its outputs ... which can also be used to make an out record ineffective.
Soooooooooo many options ....
HTH -
Ned
But I guess it should be possible to make this atleast easier with templates , but not exactly automatic.
Thanks for your help!
If you haven't already done so, have a look at the template facilities
provided by VDCT. Their use may not be completely obvious (and you
should ignore the "grouping" features which are not useful) but they
provide the ability to create template hierarchies and instantiate them.
VDCT really is the best way to design complex databases at least for
anyone from an electronics background who is used to schematic diagrams.
In the language of the VDCT template expansion stuff, "macros" pass
instance information from a parent to a child template, while "ports"
pass information from a child to its parent; the "information" I'm
talking about here are macro strings and are not directly related to
database links although they will often be expanded in them.
I'll rather stay away from VDCT
It is also relatively easy to write a DB file parser in modern scripting
languages such as Perl and Python, but it is also easy to omit some
obscure pieces of the syntax. You should be aware that future major
releases of Base will probably replace the 'C' dbStatic library with
tools written in Perl (which will have a similar Perl library for
manipulating the underlying data).
Sounds interesting
HTH,
- Andrew
Re: lexical analyzer for .db? Eric Norum
lexical analyzer for .db? Heinrich du Toit
Re: lexical analyzer for .db? Andrew Johnson
Re: lexical analyzer for .db? Heinrich du Toit
Prev: Re: lexical analyzer for .db? Heinrich du Toit
Next: Re: lexical analyzer for .db? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
