1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: lexical analyzer for .db?
To: "Rodney R. Porter" <[email protected]>
Date: Fri, 02 Nov 2007 23:16:28 +0100
Probably only true if you want to do that scan rate change in a running system.
Generally: As soon as the hardware allows different scan rates, I would always make the appropriate SCAN fields a macro that gets substituted when blowing up the template database:
If you put one input plus the attached calc into a template DB file and set both SCAN field to $(channel_scan), you can instantiate an arbitrary number of those per-channel structures, specifying the scan period of each of them (channel_scan=".2 second") to whatever seems appropriate.
Ralph
Rodney R. Porter wrote:
One disadvantage of this method is that if you ever want to change the scan
rate, the change needs to be coordinated between different records. Having
a process chain with only 1 record setting the scan rate makes it easier if
you ever foresee someone else wanting to change the scan rate.
Re: lexical analyzer for .db? Rodney R. Porter
Prev: Re: lexical analyzer for .db? Rodney R. Porter
Next: Re: lexical analyzer for .db? Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: lexical analyzer for .db? Ben Franksen
