Eric Norum wrote:
> Looks like the prototype for finite() has moved from math.h. You'll
> have to:
> a) find which header file provides this prototype (or macro) -- what
> does man finite have to say?
math.h will includes architecture/{ppc,i386}/math.h.
These file defines finite but surrounded by #if shown here.
#if !defined( __STRICT_ANSI__) && !defined(_ANSI_SOURCE) &&
(!defined(_POSIX_C_SOURCE) || defined(_DARWIN_C_SOURCE))
> b) copy src/libCom/osi/os/posix/epicsMath.h to src/libCom/osi/os/Darwin
> and add the include for the header found above
You may not like the idea to add:
#ifdef __cplusplus
extern "C" {
#endif
int finite(double);
#ifdef __cplusplus
into epicsMath.h in os/Darwin directory. But seems simpler in this case.
Noboru
> On Nov 4, 2007, at 5:03 PM, Bertrand H.J. Biritz wrote:
>> Dear Tech-Talk,
>> so I am one of those Mac fanboys (at least when it comes to the OS)
>> who installed OS X 10.5 (Leopard) as soon as it came out.
>> Naturally EPICS will not compile on it - would have been surprised if
>> it had. I get the following error message:
>> ../epicsCalcTest.cpp: In function 'double doCalc(const char*)':
>> ../epicsCalcTest.cpp:31: error: 'finite' was not declared in this scope
>> ../epicsCalcTest.cpp: In function 'void testCalc(const char*, double)':
>> ../epicsCalcTest.cpp:51: error: 'finite' was not declared in this scope
>> ../epicsCalcTest.cpp:55: error: 'finite' was not declared in this scope
>> ../epicsCalcTest.cpp: In function 'int main(int, char**)':
>> ../epicsCalcTest.cpp:170: error: 'finite' was not declared in this scope
>> make[3]: *** [epicsCalcTest.o] Error 1
>> make[2]: *** [install.darwin-ppc] Error 2
>> make[1]: *** [libCom/test.install] Error 2
>> make: *** [src.install] Error 2
>> Did I miss something in the installation instructions?
>> This is with base-3.14.9 on a PPC.
>> Thanks,
>> Bertrand
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5209
tel;fax:+81-29-879-6130
x-mozilla-html:FALSE
version:2.1
end:vcard
- Re: EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
- EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
- Re: EPICS on Mac OS X 10.5 Eric Norum
<2007>
2025
2026
<2007>
2025
2026
