1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: synchronizing data to an event
To: <[email protected]>, <[email protected]>
Date: Wed, 7 Nov 2007 08:31:55 -0700
Ron,
There is, in fact, some work in progress on an IOC based (server based)
event filtering upgrade for EPICS - which will have the potential to be
based on beam flavors, pulse counters, and any other site or device specific
parameter stored on the event queue.
http://ics-web4.sns.ornl.gov/icalepcs07/WPPA24/WPPA24.PDF
Also, several client based time correlating support library implementations
already exist for EPICS buffering the subscription updates and returning a
complete set of time correlated data based on some time synchronization
criteria. The most mature implementation is, I suspect, supplied with the
XAL package developed and in use at the SNS, and elsewhere. It's true that
the RF pulse count might be converted to time, but for a general purpose
system like EPICS event correlation out of a buffered event stream using
only time stamps has been demonstrated to be a flexible client based
approach.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Ron Rechenmacher
> Sent: Wednesday, November 07, 2007 7:42 AM
> To: [email protected]
> Cc: [email protected]
> Subject: synchronizing data to an event
> Hi,
> I did a search of tech-talk for: timing event synchronization
> The results along with my experience to date leads to the conclusion
> that synchronization by 8 byte time stamp is the only synchronization
> that
> CA currently provides. (please correct if wrong)
> The question:
>   I was wondering if there has ever been any (perhaps behind the
> scenes)
>   discussion of adding additional synchronization information to the
>   Channel Access protocol?
> Perhaps, in addition to the timestamp, a "synchronizing event"
> structure,
> which would be NULL if not used, but would otherwise have an event type
> and
> event count.
> At some linear accelerator facilities, there has been a move toward
> counting
> RF pulses and associating data collection triggered by the RF pulse
> with that
> pulse count.  Of course there would be a pulse count to time
> correlation also,
> but many people seem to embrace the main data association (in archived
> data)
> being with an event count.
> I've heard that there has been work on "beam flavors" at SLAC. (sorry
> if this
> is bogus information). But if in addition to a timestamp, data also has
> "flavor" information, then this could be considered a start to
> additional
> synchronization information?  Has there been work on this? and if so,
> has any
> progress reports been published?
> Thanks,
> Ron
synchronizing data to an event Ron Rechenmacher
Prev: RE: synchronizing data to an event Pearson, MR (Matthew)
Next: RE: Stream device Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: synchronizing data to an event Till Straumann
