Subject: |
Re: problem in running application of gpib-device |
Emmanuel Mayssat <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Wed, 07 Nov 2007 13:46:29 -0800 |
huh! You shouldn't have to move the libgpib.* files to asyn.
Those are system wide libraries.
In the configure/RELEASE of asyn set gpib_DIR=/usr/local/lib
The *.so file is a dynamic library also located in /usr/local/lib. You
probably need to set the LD_LIBRARY_PATH environment variable to
include /usr/local/lib. Check the online literature on LD_LIBRARY_PATH.
You are almost there ;-)
E
On Wed, 2007-11-07 at 17:19 +0800, zhangdemin99 wrote:
> Dear all,
> I have copied the file usr/local/libgpib.la to the
> asyn/lib/linux-x86, then, there is no error in building asyn. But
> running application, there is error:
> [zhm@localhost zhm]$cd software/gpib/psm6003/iocBoot/iocPSM6003
> [zhm@localhost zhm]../../bin/linux-x86/PSM6003 st.cmd
> ../../bin/linux-x86/PSM6003:error while loading shared
> libraries:libgpib.so.0:cannot open shared object file:No such file or
> directory
> There are always errors when building asyn....
> what shold I do next?
> Best wishes
> demin zhang
> ______________________________________________________________________
> ç æ è åï æ å æ 500 ä è æ å æ è è >>
- problem in running application of gpib-device zhangdemin99
Re: Stream device Dirk Zimoch
problem in running application of GPIB-device zhangdemin99
<2007>
2025
2026
<2007>
2025
2026
