1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM screens not updating on Linux
To: Brian Bevins <[email protected]>, [email protected]
Date: Thu, 08 Nov 2007 13:30:01 -0500
Brian,
Here's something to try.
When edm gets in this state, mouse over some widget that should be updating and do a ctl-middle-button press. A window will pop up showing the connection info for the pv and the number of value changes that have occurred. Then use another utility such as probe to watch value-change events. When you are certain a significant value change has occurred, do another ctl-middle-button press to see if edm agrees (by indicating a greater number of value changes than before and a new timestamp). If so, I would suspect some component of XWindows. If not, it could be a bug in edm or a channel access issue.
John sinclair
Brian Bevins wrote:
Hi Dirk,
We haven't been running MEDM on RHEL so I don't know if it's showing the same problem for us. I can confirm that the behavior you describe matches what has been reported to me by operators using EDM on RHEL. Exposing the window seems to solve the problem.
An X/Motif problem does seem like a possibility. We recently had to turn off the BIG-REQUESTS extension on the RHEL X servers because it generated errors for certain other (non-EPICS) applications. Does anyone know if this might be a problem for EDM? We're using xorg-x11 6.8.2 release 1.EL.19.
--Brian
Dirk Zimoch wrote:
Hi Brian,
we have seen the same effect with MEDM. I suspect a problem with either the X-server or the motif library. It is very strange that the effect appears only on some computers.
It seems that the screens don't get update requests when new values arrive. Minimizing and maximizing, or just "wiping" the screen with some other window generates the update events and the current value is shown. From this I conclude that there is no problem in EPICS and the monitor events correctly arrive. The values are just not updated on the screen. Can you verify this with EDM?
Dirk
Brian Bevins wrote:
We are in the process of converting our control room machines from HP-UX 11.11 to RedHat Enterprise Linux (rhel) 4WS. Most things seem to be working fine, but an odd problem has cropped up with EDM that we did not have on HP-UX.
Every now and then an EDM display will simply stop showing any updates to the PV's. Closing and re-opening the display gets it working again. Writes from the screen to the ioc's seem to work normally.
Has anybody else experienced a problem like this?
We are using EDM 1-10-2 on rhel 4WS (Nahant Update 5). This is the same version we have bee using on HP-UX with no problems.
Our operators love how zippy EDM runs on their new Linux boxes compared to the ancient HP hardware, but this is really denting their enthusiasm.
--Brian
EDM screens not updating on Linux Brian Bevins
Re: EDM screens not updating on Linux Dirk Zimoch
Re: EDM screens not updating on Linux Brian Bevins
Prev: Re: EDM screens not updating on Linux Brian Bevins
Next: RE: CA protocol dissector Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Motor support for PI E-621 Leicester, PJ (Pete)
