We have an Multi-sample ion source of negative ions by Ceium sputtering for AMS application. The thing sits at 250kV's The Power Supplies also sits at 250kV's. We need to control these power supplies to control the ioc source. Now the 250kV makes for some problems. One solution would be to put a PC up at 250kV.. but then you have no local control (unless you put yourself at 250kV somehow) but only remote (ssh) access. And there is the danger that a spark or something could easily kill the PC :( The other solution is to put the PC down at ground and then communicate using some fiber-link. fiber-links are expensive so we would like to only use 1 of them for all the power-supply units. So I was thinking maybe RS485 protocol. Maybe somebody did work on this type of problem already and have something that could help us? thanks -Heinrich
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
