1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Power Supply Record?
To: [email protected]
Date: Thu, 15 Nov 2007 09:44:08 +0100
Susanna Jacobson wrote:
[...] we are considering writing a custom Power Supply record. [...]
I would also welcome any advice or cautions you have, based on your experience in this area. [...]
Hi Susanna,
I had a similar idea 8 years ago for some in-house developed power supply at PSI.
Luckily I got some advice not to do it that way (Thanks Bob!).
If you use one record per power supply, your application will suffer from a lack of expandability, flexibility and usability.
Just some simple example:
Expandability:
My specification at the beginning consisted of about a dozen values for one power supply.
Within one year this did grow by a factor of 10.
I would rather have a template with 120 records connected to one power supply, then having a record with 120 fields.
Flexibility:
If you want to read a new value-type (e.g. resistance) from your PS, and let's say you have a serial connection to your PS.
Reading the new value should be possible by just adding a few lines in your protocol file and adding an "ai" record.
But if you have to add a field to a record it becomes much more trouble.
Usability:
you will read back a current and a voltage from the power supply.
Is HOPR/LOPR the display range for the current or the voltage?
Of course you can have an IHOP/ILOP and VHOP/VLOP, but since there is just one function get_graphic_double, no standard display will be able to use those fields context sensitive.
The same applies to ADEL, MDEL, HIGH, HIHI, LOW, LOLO, ....
Other people may disagree, but I would strongly advice you not to develop a power supply record.
Good luck with your power supplies anyway ;-)
Cheers
Andreas
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
[email protected], http://people.web.psi.ch/luedeke
Re: Power Supply Record? Dirk Zimoch
Re: Power Supply Record? Ralph Lange
Power Supply Record? Susanna Jacobson
Prev: Power Supply Record? Susanna Jacobson
Next: Re: Power Supply Record? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
