1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Power Supply Record?
To: "EPICS Tech Talk" <[email protected]>
Date: Mon, 19 Nov 2007 10:23:06 -0000
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Maren Purves
> Same here ...
> We're thinking of going with generic records for motor
> control again for similar reasons and to not use the motor
> record for our next (current, upgrade from non-EPICS)
> project. If you have a generic schema for all devices of the
> same sort you can even treat the ones that need special
> treatment (in our case reading in polynomial coefficients and
> calculating demand positions rather than just passing them in
> from somewhere) with genSubs, and for the ones that don't
> need special treatment have a 'straight through' function.
Then now would be a good time to urge you to try the motor *driver*
interface that now supports access to motor controller primitives
through an Asyn interface. Configure an asyn port onto the controller,
and you can connect primitive records (ai, ao, etc) to control points
such as VELOCITY, ACCEL, MOVE_ABS, LOW_LIMIT, etc.
I know that it currently comes bundled with the motor *record*, but you
don't have to actually use the record on top of it all.
Assistance in supporting/porting other controllers than the original
PMAC, XPS, MM4000 (and tentatively OMS58/MAXv) will be gladly provided.
Peter Denison, Senior Software Engineer, Diamond Light Source Ltd.
Tel: +44 1235 778511
(apologies in advance for the lines below. Some bits are a legal
requirement and I have no control over them)
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Re: Power Supply Record? Maren Purves
Prev: question about caTCL_20070625 marco_hair
Next: Problem with assert in dbLock.c David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Power Supply Record? Maren Purves
Next: Re: Power Supply Record? Ralph Lange
