1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Streams questions
To: [email protected]
Date: Tue, 20 Nov 2007 16:09:57 -0500
Hello!
I've run into a problem I'm guessing others have solved using the
Streams module.  I have a device that outputs reads in the format:
U1\r\n+00011-01\r\n
meaning 11e-01 , which would be the preferred format for using a
general format specifier in the protocol file.
What would be the format to successfully read in this number from the
Streams protocol file?
(Or, will I have to run as a string read through a c filter program,
sub record)
Thank you!
Eric
Re: Streams questions Dirk Zimoch
Prev: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
Next: RE: Streams questions Mohan Ramanathan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
Next: Re: Streams questions Dirk Zimoch
