1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: current measurement - hardware
To: EPICS Techtalk <[email protected]>
Date: Mon, 26 Nov 2007 16:25:47 +0200
Hi guys
I'm looking for some information on how you solve this problem...
We need to measure currents.. from harps and slits and faraday cups.
All of this gives of currents that is important.
Some of the currents we measure with keithleys but it is way to expensive to buy keithleys for harps as you will need 100's of them :)
We need to measure currents between nA and uA range for harps and slits.
For faraday cups this sometimes goes to 100+ uA but our main problem is harps/slits.
I hope that we are not the first to have this problem, is there some cost effective method to solve this problem? That can give descent results.
The problem can basically be given as:
How do I measure 50+ current inputs (harp = 96, 4 per slit-set) across a wide range (2nA fullscale = 50pA sensitive up to 100uA full scale) still have resonable accuracy especially between the lines and have a descent update rate and not 2 high noise levels.
(I guess noise can to some extend be solved with a software filter if updates are high enough)
Thanks for your support :)
-Heinrich
Re: current measurement - hardware Tim Mooney
Re: current measurement - hardware David Dudley
Re: current measurement - hardware Rolf Keitel
Prev: Re: JCA using problem Daron Chabot
Next: Re: current measurement - hardware Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: JCA using problem J. Lewis Muir
