FYI, here are the email exchanges we had in August regarding the JCA/JNI compilation on Windows with VC. Also, Ernest Williams discovered that even after the JCA/JNI library successfully compiled, we still need to run the VC manifest utility to fix the runtime library loading problem:
C:\epicsExtensions\lib\win32-x86>mt.exe -manifest jca.dll.manifest -outputresource:jca.dll;2
After this step (and, of course, include the path to jca.dll in the %PATH%), the JCA/JNI works fine on both XP and Vista.
Paul
~~~~~~~~~~~~~begin forwarded emails~~~~~
Hi Jeff,
Thanks for the info.
In our case we actually trying to use EPICS R3.14.8.2.
We do need epicsShareFunc, right?
Can you send examples of how to deal with this?
If indeed, I remove epicsShareFunc, like so:
// Be backward compatible, EPICS3.14.9(.2) required.
#if ((EPICS_REVISION >= 14) && (EPICS_MODIFICATION >= 9)) #include <epicsExit.h> #else epicsShareFunc void epicsShareAPI epicsExit(int status); int epicsShareAPI epicsAtThreadExit(
void (*epicsExitFunc)(void *arg),void *arg){ return 0; } #endif ==========================================================================
Everything compiles, like so:
C:\epicsExtensions\src\jca-2.3.1>ant
Buildfile: build.xml
build.core.java:
[echo] Building core classes
[echo] Copying ressources
[echo] Done
-init:
build.core.jni.dirs:
build.core.jni.depend:
[echo] Building native header files
[echo] Done
build.core.jni.objs:
[echo] Building native object files
[applyex] C:\Program Files\Microsoft Visual Studio 8\VC\bin\cl -nologo -EHsc - c -GR -GL -D__STDC__=0 -Ox -W3 -w44355 -MD -IC:\Program Files\Java\jdk1.6.0_02\j re/../include -IC:\Program Files\Java\jdk1.6.0_02\jre/../include/WIN32 -IC:\epic sBase\R3.14.8.2/include -IC:\epicsBase\R3.14.8.2/include/os/WIN32 -IC:/Program F iles/Microsoft Visual Studio 8/VC/include -IO.win32-x86 -FoC:\epicsExtensions\sr c\jca-2.3.1\O.win32-x86\JNI.obj C:\epicsExtensions\src\jca-2.3.1\src\core\gov\ap
s\jca\jni\JNI.cpp
[applyex] JNI.cpp
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(40
2) : warning C4996: 'strncpy' was declared deprecated
[applyex] C:/Program Files/Microsoft Visual Studio 8/VC/include\string
.h(156) : see declaration of 'strncpy'
[applyex] Message: 'This function or variable may be unsafe. Consider
using strncpy_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. S ee online help for details.'
4) : warning C4996: 'strncat' was declared deprecated
.h(143) : see declaration of 'strncat'
using strncat_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. S ee online help for details.'
5) : warning C4996: 'strncat' was declared deprecated
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(60
0) : warning C4996: 'sprintf' was declared deprecated
[applyex] C:/Program Files/Microsoft Visual Studio 8/VC/include\stdio.
h(345) : see declaration of 'sprintf'
using sprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. S ee online help for details.'
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(63
1) : warning C4003: not enough actual parameters for macro 'INITIALIZE_CALLBACK'
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(87
8) : warning C4003: not enough actual parameters for macro 'INITIALIZE_CALLBACK'
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(90
0) : warning C4003: not enough actual parameters for macro 'INITIALIZE_CALLBACK'
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(91
9) : warning C4003: not enough actual parameters for macro 'INITIALIZE_CALLBACK'
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(93
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(96
[applyex] C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(12
12) : warning C4996: 'strncpy' was declared deprecated
[echo] Done
build.core.jni.lib:
[echo] Building native library: jca.dll
[applyex] C:\Program Files\Microsoft Visual Studio 8\VC\bin\link /nologo /LTCG /subsystem:windows /dll /incremental:no /opt:ref /release /LIBPATH:C:/Program F iles/Microsoft Visual Studio 8/VC/lib /LIBPATH:C:\epicsBase\R3.14.8.2/lib/win32-
x86 ca.lib Com.lib /out:C:\epicsExtensions\src\jca-2.3.1\O.win32-x86\jca.dll C:\ epicsExtensions\src\jca-2.3.1\O.win32-x86\JNI.obj
[applyex] Creating library C:\epicsExtensions\src\jca-2.3.1\O.win32-x86\jca
.lib and object C:\epicsExtensions\src\jca-2.3.1\O.win32-x86\jca.exp
[applyex] Generating code
[applyex] Finished generating code
[propertyfile] Updating property file: C:\epicsExtensions\src\jca-2.3.1\O.core\g
ov\aps\jca\JCALibrary.properties
[echo] Done
build.core.jni:
[echo] done
build.core:
[jar] Building jar: C:\epicsExtensions\src\jca-2.3.1\O.core\jca.jar
[echo] done
build:
BUILD SUCCESSFUL
Total time: 1 second
Ernest
-----Original Message-----
Sent: Thu 8/23/2007 2:49 PM
To: Williams Jr., Ernest L.
Cc: [email protected]
Subject: RE: Trying to build JCA under Windows
Ernest,
There is a comment in the top of libCom/misc/shareLib.h that shows how to use the epicsShareFunc macro.
In summary, you have to define epicsExportSharedSymbols before including the header file with epicsShareFunc in it if you are exporting that function, and should not have epicsExportSharedSymbols defined before including the header file if you are importing the functions in that header file. This gets more complicated if you are creating a DLL that imports from other DLLs. I can send examples showing how to deal with that situation as your needs dictate.
Also, you need to use the correct visual c++ build options when creating a DLL or importing from the DLL. The typical build options for clients that import from an EPICS DLL are in the ca ref manual (hopefully they are reasonably up to date).
Looking, very quickly, at this code one might surmise that the epicsShareFunc keyword should simply be removed because there is no intent to export or import these dummy functions (to or from a DLL) when the epics revision is less than R3.14.
In our case, we are trying to use EPICS R3.14.8.2 ===============================================================================
#else
epicsShareFunc int epicsShareAPI epicsAtThreadExit(
#endif
Jeff
From: Williams Jr., Ernest L. [mailto:[email protected]]
Sent: Thursday, August 23, 2007 12:51 AM
Cc: [email protected]; [email protected]
Hi Matej,
jca-2.3.1 does compile under EPICS R3.14.9.
Jeff any ideas on this one? Read the reference below from Microsoft.
Ernest
Sent: Wed 8/22/2007 11:48 PM
Subject: Trying to build JCA under Windows
Hi Matej,
I am trying to build jca under windows:
-IC:\epic
-IC:/Program F
s\jca\jni\JNI.cpp
[applyex] JNI.cpp
[applyex]
C:\epicsExtensions\src\jca-2.3.1\src\core\gov\aps\jca\jni\JNI.cpp(10
0) : error C2491: 'epicsAtThreadExit' : definition of dllimport function not all owed
Here is the offending line of code:
========== JNI.cpp ============================
#else
#endif
Below is a reference from Microsoft MSDN:
You can only apply the __declspec(dllimport) keyword to declarations. You cannot apply the __declspec(dllimport) keyword to implement functions. The purpose of this keyword is to declare the implementation of a function by a DLL. Similarly, if you apply the __declspec(dllimport) keyword to a data member, you receive the initial data from a DLL. Therefore, you cannot assign a value in your code initially.
You receive the Compiler C2491 error message when you try to compile the following code:
// function definition
void __declspec(dllimport) funcB() { // error C2491: 'funcB' : definition
of dllimport function not allowed
This behavior occurs because you defined the function implementation as dllimport. To avoid this compiler error, do not define the function, but instead declare the function as follows:
// function declaration
void __declspec(dllimport) funcB(); // ok
int main() {
Similarly, you receive the Compiler C2491 error message when you try to compile the following code:
//defining data member
extern __declspec(dllimport) int code = 1; // error C2491: 'code' :
definition of dllimport data not allowed
You receive this error message because you defined the data member as dllimport. To avoid this compiler error, do not define the data member, but instead declare the data member as follows:
// declaring data member
extern __declspec(dllimport) int code; // ok
~~~~~~~end forwarded emails~~~~~~~
Sent: Wednesday, November 28, 2007 5:18 PM
To: Chu, Chungming Paul; '???'
Subject: RE: JCA using problem
Hi Paul,
I think there may have a problem when compiling the JCA/JNI library using MSVC2005.
With my old JCA/JNI library (v2.1.7) compiled using MSVC2003 free toolkit, the code works fine.
With the library compiled by MSVC2005, a message windows is popped up.
which says as following: (The JCALibrary.properties is same.)
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\java\jdk1.5.0_14\bin\java.exe
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
A tracking message throws from java code is as fllowing:
Exception in thread "main" java.lang.UnsatisfiedLinkError:
C:\Java\epics\jca-2.1.7\O.win32-x86\jca.dll:
A dynamic link library (DLL) initialization routine failed
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at gov.aps.jca.jni.JNI$1.run(JNI.java:100)
at java.security.AccessController.doPrivileged(Native
Method)
at gov.aps.jca.jni.JNI.init(JNI.java:110)
at
gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:109)
at
gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:145)
at
gov.aps.jca.jni.ThreadSafeContext.createChannel(ThreadSafeContext.java:330)
at gov.aps.jca.Context.createChannel(Context.java:113)
at test.main(test.java:25)
For the version 2.3.1, a similar error was thrown also.
Guobao
From: Chu, Chungming Paul [mailto:[email protected]]
Sent: 2007年11月29日 2:12 AM
To: Guobao Shen (KEK); ???
Yes, I think Guobao is right. I tested your code on my Windows box and it worked fine (with everything set correctly). The output looks like this:
CLASS : gov.aps.jca.jni.ThreadSafeContext PREEMPTIVE_CALLBACK : true ADDR_LIST : xxxxxx.sns.ornl.gov AUTO_ADDR_LIST : false CONNECTION_TIMEOUT :
30.0 BEACON_PERIOD : 15.0 REPEATER_PORT : 5065 SERVER_PORT : 5064 MAX_ARRAY_BYTES : 16384
EVENT_DISPATCHER: gov.aps.jca.event.QueuedEventDispatcher@1749757
PRIORITY : 1
gov.aps.jca.TimeoutException: pendIO timed out
Of course, for my ADDR_LIST, I don't have a channel called 'light' and got pendIO timed out error.
I also attach my JCALibrary.properties file from my Windows box (it's set to use JCA/JNI, same as in your example). If you're using Linux, you need to follow the Linux syntax.
If you need further help, could you send more detailed info about the exception thrown and maybe screen print-out?
Paul
On Behalf Of Guobao Shen (KEK)
Sent: Tuesday, November 27, 2007 6:32 PM
To: '鲍春雷'; [email protected]
Hi Bao,
You need set some environment parameter properly for JCA in JCALibrary.properties file before you start using it.
There is a tutorial under doc directory if you downloaded the source code.
Some some detail explanation can be found in that file about how to setJCALibrary.properties .
BTW: Which OS do you use, Linux, Win/XP, ...?
Do you compile the JCA library from source code by yourself?
Guobao Shen
To: [email protected]
Subject: JCA using problem
Hello,all
I am using JCA to do some experment.But the first program can not run.The error message is:java.lang.IllegalStateException: Context not initialized.
My environment:
JDK 1.5
JCA 2.3.1
EPICS 3.14.8
The program:
import gov.aps.jca.Channel;
import gov.aps.jca.Context;
import gov.aps.jca.JCALibrary;
public class test {
public static void main(String[] args) {
try {
JCALibrary jca= JCALibrary.getInstance();
Context ctxt=
jca.createContext(JCALibrary.JNI_THREAD_SAFE);
ctxt.printInfo();
Channel ch= ctxt.createChannel("light");
ctxt.pendIO(5.0);
ch.printInfo();
ch.destroy();
ctxt.destroy();
} catch(Exception ex) {
System.err.println(ex);
BaoChunlei
Control Group,IHEP
- JCA using problem 鲍春雷
- RE: JCA using problem Guobao Shen (KEK)
how to recv data by raw socket under VxWorks 黄松
<2007>
2025
2026
Re: JCA using problem J. Lewis Muir
<2007>
2025
2026
