1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Help with udev
To: <[email protected]>, "Denison, PN (Peter)" <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>
Cc: "Scott D. Davilla" <[email protected]>
Date: Fri, 21 Dec 2007 13:15:37 -0600
Folks,
Thanks to all of you for responding!
I'm making progress, but I'm not quite there.
Guy's suggestion about the case-sensitivity on the idVendor was the problem.  I changed it from 10E9 to 10e9 and then the rule took effect.  I changed ATTRS to SYSFS on Peter's suggestion, but I found that actually either one works once the case sensitivity problem is fixed.
[epics@baja rules.d]# more 80-saturn.rules
SUBSYSTEM=="usb_device",ACTION=="add",SYSFS{idVendor}=="10e9",SYSFS{idProduct}=="0700",MODE="0666"
SUBSYSTEM=="usb_device",ACTION=="add",SYSFS{idVendor}=="10e9",SYSFS{idProduct}=="0701",MODE="0666"
Now when I turn on the Saturn and I look at the device I see the following:
[epics@baja ~]$ ls -l /dev/bus/usb/005
total 0
crw-r--r-- 1 root root 189, 512 2007-12-20 17:44 001
total 0
crw-r--r-- 1 root root 189, 529 2007-12-21 13:01 018
total 0
crw-rw-rw- 1 root root 189, 529 2007-12-21 13:01 018
The first time I looked it was still powered off.  The next time I looked it was powered on but the rule had not yet taken effect.  The last time I looked, about 2 seconds later, the rule had taken effect, and the permissions are 666 as I wanted.
That is the good news.  The bad news is that setting the permissions on that device,
/dev/bus/usb/005/018
does not allow a non-privileged user to access the device.  In order for a non-privileged use to access the device, I find that I need to set the permissions to 666 on
/proc/bus/usb/005/018
i.e. the /proc filesystem, not the /dev filesystem.  If I change the permissions on the /proc filesystem manually then I can run the IOC in a non-privileged account.
I am not a Linux expert by any means.  What is the difference between the /dev and /proc filesystems?  Peter also mentioned the /sys file system.  How is that related?
I am using the libusb library to access the device.  With that API one simply calls usb_find_busses and usb_find_devices to locate the device you are interested in.  You don't specify the file system anywhere.
Any ideas how to get the permissions I need set on the device?
Sent: Fri 12/21/2007 1:27 AM
To: Mark Rivers
Subject: Re: Help with udev
A couple of suggestions (based on my limited experience with udev):
1: There's a 'udevtest' command that you can use to do a dry run of the udev actions for a particular device, this might cut down on the amount of output you have to go through.
2: I don't suppose the matching on the 'idVendor' attribute is case-sensitive?
Good luck,
Guy
>Folks,
>I have written EPICS device support for a USB device (Saturn spectroscopy system from XIA).  It is working fine under both Windows and Linux.
>However, on Linux I have been running the IOC application with root privilege, which I would like to avoid.  The problem arises because USB devices are created dynamically, so one cannot statically give them the desired mode (e.g. 666, 660, etc.).
>My understanding is that one can use the Linux "udev" facility to handle this.  I've found some examples of how to do it on the Web, but I can't seem to get it to work.  I was hoping someone might be able to tell me what I'm doing wrong.
>I've created a file, /etc/udev/rules.d/80-saturn.rules
>[epics@baja rules.d]$ more /etc/udev/rules.d/80-saturn.rules
>SUBSYSTEM=="usb_device",ACTION=="add",ATTRS{idVendor}=="10E9",ATTRS{idProduct}=="0700",MODE="0666"
>SUBSYSTEM=="usb_device",ACTION=="add",ATTRS{idVendor}=="10E9",ATTRS{idProduct}=="0701",MODE="0666"
>This should set the permissions on the device to 666 when the USB device is added.  I have verified that these are the correct idVendor and idProduct with udevinfo:
>[epics@baja udev]# /usr/bin/udevinfo --attribute-walk --name=/dev/bus/usb/005/008
>Udevinfo starts with the device specified by the devpath and then
>walks up the chain of parent devices. It prints for every device
>found, all possible attributes in the udev rules key format.
>A rule to match, can be composed by the attributes of the device
>and the attributes from one single parent device.
>  looking at device '/class/usb_device/usbdev5.8':
>    KERNEL=="usbdev5.8"
>    DRIVER==""
>    ATTR{dev}=="189:519"
>  looking at parent device '/devices/pci0000:00/0000:00:1d.7/usb5/5-1':
>    KERNELS=="5-1"
>    SUBSYSTEMS=="usb"
>    DRIVERS=="usb"
>    ATTRS{product}=="EZ-USB"
>    ATTRS{manufacturer}=="Cypress"
>    ATTRS{quirks}=="0x0"
>    ATTRS{maxchild}=="0"
>    ATTRS{version}==" 2.00"
>    ATTRS{devnum}=="8"
>    ATTRS{busnum}=="5"
>    ATTRS{speed}=="480"
>    ATTRS{bMaxPacketSize0}=="64"
>    ATTRS{bNumConfigurations}=="1"
>    ATTRS{bDeviceProtocol}=="00"
>    ATTRS{bDeviceSubClass}=="00"
>    ATTRS{bDeviceClass}=="00"
>    ATTRS{bcdDevice}=="0000"
>    ATTRS{idVendor}=="10e9"
>    ATTRS{bMaxPower}=="100mA"
>    ATTRS{bmAttributes}=="80"
>    ATTRS{bConfigurationValue}=="1"
>    ATTRS{bNumInterfaces}==" 1"
>    ATTRS{configuration}==""
>    ATTRS{dev}=="189:519"
>I've increased the debugging level of udev, and restarted udevd.  I can see in the log file that it has read my rules file.
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/05-udev-early.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/06-udev-rh-early.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/10-libifp.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/40-multipath.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/50-udev.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-libmtp.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-libnjb.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-libsane.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-net.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-pcmcia.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-persistent-input.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-persistent-storage.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/60-wacom.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/80-saturn.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/85-pcscd_ccid.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/85-pcscd_egate.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/90-alsa.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/90-hal.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/95-pam-console.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/95-udev-late.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/99-fuse.rules' as rules file
>Dec 20 18:21:37 baja udevd[3584]: parse_file: reading '/etc/udev/rules.d/bluetooth.rules' as rules file
>Dec 20 18:21:37 baja udevd[3585]: main: initialize max_childs to 2114
>Dec 20 18:21:37 baja udevd[3585]: main: initialize max_childs_running to 40
>However, when powering the Saturn off and on (and thereby creating a new Linux USB device), the permissions are not what I want, they are still 644, not 666.  If I manually change the permissions on /proc/bus/usb/005/008 to 666 then non-privileged users can run the IOC application.  But the next time I power off and on the device, it will be device /proc/bus/usb/005/009, and again I would need to log in as root to change the permisions.
>Here is the output of the log file when the device is powered on and found by Linux.
>Dec 20 18:21:56 baja kernel: usb 5-1: new high speed USB device using ehci_hcd and address 8
>Dec 20 18:21:56 baja kernel: usb 5-1: configuration #1 chosen from 1 choice
>Dec 20 18:21:56 baja udevd[3585]: udev_event_run: seq 1037 forked, pid [3600], 'add' 'usb', 0 seconds old
>Dec 20 18:21:57 baja udevd-event[3600]: udev_rules_get_name: rule applied, '5-1' becomes 'bus/usb/005/008'
>Dec 20 18:21:57 baja udevd-event[3600]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fdevices\x2fpci0000:00\x2f0000:00:1d.7\x2fusb5\x2f5-1: No such file or directory
>Dec 20 18:21:57 baja udevd-event[3600]: udev_node_add: creating device node '/dev/bus/usb/005/008', major=189, minor=519, mode=0644, uid=0, gid=0
>Dec 20 18:21:57 baja udevd-event[3600]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f005\x2f008/\x2fdevices\x2fpci0000:00\x2f0000:00:1d.7\x2fusb5\x2f5-1'
>Dec 20 18:21:57 baja udevd-event[3600]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:57 baja udevd-event[3600]: pass_env_to_socket: passed 322 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:57 baja udevd-event[3600]: run_program: '/sbin/pam_console_apply /dev/bus/usb/005/008 '
>Dec 20 18:21:57 baja udevd-event[3600]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:57 baja udevd-event[3600]: udev_event_run: seq 1037 finished
>Dec 20 18:21:57 baja udevd[3585]: udev_done: seq 1037, pid [3600] exit with 0, 1 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1038 forked, pid [3602], 'add' 'usb_endpoint', 1 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1039 forked, pid [3603], 'add' 'usb', 0 seconds old
>Dec 20 18:21:57 baja udevd-event[3602]: udev_rules_get_name: add symlink 'usbdev5.8_ep00'
>Dec 20 18:21:57 baja udevd-event[3602]: udev_rules_get_name: rule applied, 'usbdev5.8_ep00' becomes 'bus/usb/5/8_ep/00'
>Dec 20 18:21:57 baja udevd-event[3603]: run_program: '/sbin/modprobe usb:v10E9p0701d0000dc00dsc00dp00icFFisc00ip00'
>Dec 20 18:21:57 baja udevd-event[3603]: run_program: '/sbin/modprobe' (stderr) 'FATAL: Module usb:v10E9p0701d0000dc00dsc00dp00icFFisc00ip00 not found.'
>Dec 20 18:21:57 baja udevd-event[3603]: run_program: '/sbin/modprobe' returned with status 1
>Dec 20 18:21:57 baja udevd-event[3603]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:57 baja udevd-event[3603]: pass_env_to_socket: passed 343 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:57 baja udevd-event[3603]: run_program: '/sbin/pam_console_apply  '
>Dec 20 18:21:57 baja udevd-event[3603]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:57 baja udevd-event[3603]: udev_event_run: seq 1039 finished
>Dec 20 18:21:57 baja udevd[3585]: udev_done: seq 1039, pid [3603] exit with 1, 0 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1040 forked, pid [3606], 'add' 'usb_endpoint', 0 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1041 forked, pid [3607], 'add' 'usb_endpoint', 0 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1042 forked, pid [3608], 'add' 'usb_endpoint', 0 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1043 forked, pid [3609], 'add' 'usb_endpoint', 0 seconds old
>Dec 20 18:21:57 baja udevd[3585]: udev_event_run: seq 1044 forked, pid [3610], 'add' 'usb_device', 0 seconds old
>Dec 20 18:21:57 baja udevd-event[3610]: run_program: '/bin/sh -c 'K=usbdev5.8; K=${K#usbdev}; printf bus/usb/%03i/%03i ${K%%.*} ${K#*.}''
>Dec 20 18:21:57 baja udevd-event[3610]: run_program: '/bin/sh' (stdout) 'bus/usb/005/008'
>Dec 20 18:21:57 baja udevd-event[3610]: run_program: '/bin/sh' returned with status 0
>Dec 20 18:21:57 baja udevd-event[3610]: udev_rules_get_name: rule applied, 'usbdev5.8' becomes 'bus/usb/005/008'
>Dec 20 18:21:57 baja udevd-event[3608]: udev_rules_get_name: add symlink 'usbdev5.8_ep06'
>Dec 20 18:21:57 baja udevd-event[3608]: udev_rules_get_name: rule applied, 'usbdev5.8_ep06' becomes 'bus/usb/5/8_ep/06'
>Dec 20 18:21:57 baja udevd-event[3609]: udev_rules_get_name: add symlink 'usbdev5.8_ep88'
>Dec 20 18:21:57 baja udevd-event[3606]: udev_rules_get_name: add symlink 'usbdev5.8_ep82'
>Dec 20 18:21:57 baja udevd-event[3609]: udev_rules_get_name: rule applied, 'usbdev5.8_ep88' becomes 'bus/usb/5/8_ep/88'
>Dec 20 18:21:57 baja udevd-event[3607]: udev_rules_get_name: add symlink 'usbdev5.8_ep01'
>Dec 20 18:21:57 baja udevd-event[3606]: udev_rules_get_name: rule applied, 'usbdev5.8_ep82' becomes 'bus/usb/5/8_ep/82'
>Dec 20 18:21:57 baja udevd-event[3607]: udev_rules_get_name: rule applied, 'usbdev5.8_ep01' becomes 'bus/usb/5/8_ep/01'
>Dec 20 18:21:57 baja udevd-event[3602]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep00: No such file or directory
>Dec 20 18:21:57 baja udevd-event[3602]: udev_node_add: creating device node '/dev/bus/usb/5/8_ep/00', major=251, minor=10, mode=0644, uid=0, gid=0
>Dec 20 18:21:58 baja udevd-event[3602]: name_index: creating index: '/dev/.udev/names/usbdev5.8_ep00/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f5\x2f8_ep\x2f00/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: udev_node_update_symlinks: update symlink 'usbdev5.8_ep00' of '/class/usb_endpoint/usbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: udev_db_get_devices_by_name: found index directory '/dev/.udev/names/usbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: update_link: found 1 devices with name 'usbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: update_link: found '/class/usb_endpoint/usbdev5.8_ep00' for 'usbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: update_link: compare (our own) priority of '/class/usb_endpoint/usbdev5.8_ep00' 0 >= 0
>Dec 20 18:21:58 baja udevd-event[3602]: update_link: 'usbdev5.8_ep00' with target 'bus/usb/5/8_ep/00' has the highest priority 0, create it
>Dec 20 18:21:58 baja udevd-event[3602]: node_symlink: creating symlink '/dev/usbdev5.8_ep00' to 'bus/usb/5/8_ep/00'
>Dec 20 18:21:58 baja udevd-event[3602]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:58 baja udevd-event[3602]: pass_env_to_socket: passed 319 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:58 baja udevd-event[3602]: run_program: '/sbin/pam_console_apply /dev/bus/usb/5/8_ep/00 /dev/usbdev5.8_ep00'
>Dec 20 18:21:58 baja udevd-event[3602]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:58 baja udevd-event[3602]: udev_event_run: seq 1038 finished
>Dec 20 18:21:58 baja udevd[3585]: udev_done: seq 1038, pid [3602] exit with 0, 2 seconds old
>Dec 20 18:21:58 baja udevd-event[3608]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep06: No such file or directory
>Dec 20 18:21:58 baja udevd-event[3608]: udev_node_add: creating device node '/dev/bus/usb/5/8_ep/06', major=251, minor=13, mode=0644, uid=0, gid=0
>Dec 20 18:21:58 baja udevd-event[3608]: name_index: creating index: '/dev/.udev/names/usbdev5.8_ep06/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3608]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f5\x2f8_ep\x2f06/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3608]: udev_node_update_symlinks: update symlink 'usbdev5.8_ep06' of '/class/usb_endpoint/usbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3608]: udev_db_get_devices_by_name: found index directory '/dev/.udev/names/usbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3608]: update_link: found 1 devices with name 'usbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3608]: update_link: found '/class/usb_endpoint/usbdev5.8_ep06' for 'usbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3608]: update_link: compare (our own) priority of '/class/usb_endpoint/usbdev5.8_ep06' 0 >= 0
>Dec 20 18:21:58 baja udevd-event[3608]: update_link: 'usbdev5.8_ep06' with target 'bus/usb/5/8_ep/06' has the highest priority 0, create it
>Dec 20 18:21:58 baja udevd-event[3608]: node_symlink: creating symlink '/dev/usbdev5.8_ep06' to 'bus/usb/5/8_ep/06'
>Dec 20 18:21:58 baja udevd-event[3608]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:58 baja udevd-event[3608]: pass_env_to_socket: passed 309 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:58 baja udevd-event[3608]: run_program: '/sbin/pam_console_apply /dev/bus/usb/5/8_ep/06 /dev/usbdev5.8_ep06'
>Dec 20 18:21:58 baja udevd-event[3609]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep88: No such file or directory
>Dec 20 18:21:58 baja udevd-event[3609]: udev_node_add: creating device node '/dev/bus/usb/5/8_ep/88', major=251, minor=14, mode=0644, uid=0, gid=0
>Dec 20 18:21:58 baja udevd-event[3608]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:58 baja udevd-event[3608]: udev_event_run: seq 1042 finished
>Dec 20 18:21:58 baja udevd[3585]: udev_done: seq 1042, pid [3608] exit with 0, 1 seconds old
>Dec 20 18:21:58 baja udevd-event[3609]: name_index: creating index: '/dev/.udev/names/usbdev5.8_ep88/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3609]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f5\x2f8_ep\x2f88/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3609]: udev_node_update_symlinks: update symlink 'usbdev5.8_ep88' of '/class/usb_endpoint/usbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3609]: udev_db_get_devices_by_name: found index directory '/dev/.udev/names/usbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3609]: update_link: found 1 devices with name 'usbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3609]: update_link: found '/class/usb_endpoint/usbdev5.8_ep88' for 'usbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3609]: update_link: compare (our own) priority of '/class/usb_endpoint/usbdev5.8_ep88' 0 >= 0
>Dec 20 18:21:58 baja udevd-event[3609]: update_link: 'usbdev5.8_ep88' with target 'bus/usb/5/8_ep/88' has the highest priority 0, create it
>Dec 20 18:21:58 baja udevd-event[3609]: node_symlink: creating symlink '/dev/usbdev5.8_ep88' to 'bus/usb/5/8_ep/88'
>Dec 20 18:21:58 baja udevd-event[3609]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:58 baja udevd-event[3609]: pass_env_to_socket: passed 309 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:58 baja udevd-event[3609]: run_program: '/sbin/pam_console_apply /dev/bus/usb/5/8_ep/88 /dev/usbdev5.8_ep88'
>Dec 20 18:21:58 baja udevd-event[3606]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep82: No such file or directory
>Dec 20 18:21:58 baja udevd-event[3606]: udev_node_add: creating device node '/dev/bus/usb/5/8_ep/82', major=251, minor=11, mode=0644, uid=0, gid=0
>Dec 20 18:21:58 baja udevd-event[3609]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:58 baja udevd-event[3609]: udev_event_run: seq 1043 finished
>Dec 20 18:21:58 baja udevd[3585]: udev_done: seq 1043, pid [3609] exit with 0, 1 seconds old
>Dec 20 18:21:58 baja udevd-event[3606]: name_index: creating index: '/dev/.udev/names/usbdev5.8_ep82/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3606]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f5\x2f8_ep\x2f82/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3606]: udev_node_update_symlinks: update symlink 'usbdev5.8_ep82' of '/class/usb_endpoint/usbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3606]: udev_db_get_devices_by_name: found index directory '/dev/.udev/names/usbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3606]: update_link: found 1 devices with name 'usbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3606]: update_link: found '/class/usb_endpoint/usbdev5.8_ep82' for 'usbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3607]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep01: No such file or directory
>Dec 20 18:21:58 baja udevd-event[3606]: update_link: compare (our own) priority of '/class/usb_endpoint/usbdev5.8_ep82' 0 >= 0
>Dec 20 18:21:58 baja udevd-event[3606]: update_link: 'usbdev5.8_ep82' with target 'bus/usb/5/8_ep/82' has the highest priority 0, create it
>Dec 20 18:21:58 baja udevd-event[3607]: udev_node_add: creating device node '/dev/bus/usb/5/8_ep/01', major=251, minor=12, mode=0644, uid=0, gid=0
>Dec 20 18:21:58 baja udevd-event[3606]: node_symlink: creating symlink '/dev/usbdev5.8_ep82' to 'bus/usb/5/8_ep/82'
>Dec 20 18:21:58 baja udevd-event[3606]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:58 baja udevd-event[3606]: pass_env_to_socket: passed 309 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:58 baja udevd-event[3607]: name_index: creating index: '/dev/.udev/names/usbdev5.8_ep01/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3607]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f5\x2f8_ep\x2f01/\x2fclass\x2fusb_endpoint\x2fusbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3606]: run_program: '/sbin/pam_console_apply /dev/bus/usb/5/8_ep/82 /dev/usbdev5.8_ep82'
>Dec 20 18:21:58 baja udevd-event[3607]: udev_node_update_symlinks: update symlink 'usbdev5.8_ep01' of '/class/usb_endpoint/usbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3607]: udev_db_get_devices_by_name: found index directory '/dev/.udev/names/usbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3607]: update_link: found 1 devices with name 'usbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3607]: update_link: found '/class/usb_endpoint/usbdev5.8_ep01' for 'usbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3607]: update_link: compare (our own) priority of '/class/usb_endpoint/usbdev5.8_ep01' 0 >= 0
>Dec 20 18:21:58 baja udevd-event[3607]: update_link: 'usbdev5.8_ep01' with target 'bus/usb/5/8_ep/01' has the highest priority 0, create it
>Dec 20 18:21:58 baja udevd-event[3607]: node_symlink: creating symlink '/dev/usbdev5.8_ep01' to 'bus/usb/5/8_ep/01'
>Dec 20 18:21:58 baja udevd-event[3606]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:58 baja udevd-event[3606]: udev_event_run: seq 1040 finished
>Dec 20 18:21:58 baja udevd-event[3607]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:58 baja udevd[3585]: udev_done: seq 1040, pid [3606] exit with 0, 1 seconds old
>Dec 20 18:21:58 baja udevd-event[3607]: pass_env_to_socket: passed 309 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:58 baja udevd-event[3607]: run_program: '/sbin/pam_console_apply /dev/bus/usb/5/8_ep/01 /dev/usbdev5.8_ep01'
>Dec 20 18:21:58 baja udevd-event[3607]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:58 baja udevd-event[3607]: udev_event_run: seq 1041 finished
>Dec 20 18:21:58 baja udevd[3585]: udev_done: seq 1041, pid [3607] exit with 0, 1 seconds old
>Dec 20 18:21:59 baja udevd-event[3610]: udev_db_get_device: no db file to read /dev/.udev/db/\x2fclass\x2fusb_device\x2fusbdev5.8: No such file or directory
>Dec 20 18:21:59 baja udevd-event[3610]: udev_node_add: creating device node '/dev/bus/usb/005/008', major=189, minor=519, mode=0644, uid=0, gid=0
>Dec 20 18:21:59 baja udevd-event[3610]: udev_node_mknod: preserve file '/dev/bus/usb/005/008', because it has correct dev_t
>Dec 20 18:21:59 baja udevd-event[3610]: name_index: creating index: '/dev/.udev/names/bus\x2fusb\x2f005\x2f008/\x2fclass\x2fusb_device\x2fusbdev5.8'
>Dec 20 18:21:59 baja udevd-event[3610]: pass_env_to_socket: passed -1 bytes to socket '/org/kernel/udev/monitor',
>Dec 20 18:21:59 baja udevd-event[3610]: pass_env_to_socket: passed 273 bytes to socket '/org/freedesktop/hal/udev_event',
>Dec 20 18:21:59 baja udevd-event[3610]: run_program: '/sbin/pam_console_apply /dev/bus/usb/005/008 '
>Dec 20 18:21:59 baja udevd-event[3610]: run_program: '/sbin/pam_console_apply' returned with status 0
>Dec 20 18:21:59 baja udevd-event[3610]: udev_event_run: seq 1044 finished
>Dec 20 18:21:59 baja udevd[3585]: udev_done: seq 1044, pid [3610] exit with 0, 2 seconds old
>Any ideas?
>Thanks,
>Mark
Prev: Re: A patch for medm Kate Feng
Next: mca R6-10 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Help with udev Dr. Peter Hartmann
