1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE:problem in running application of PSM6003
To: [email protected]
Date: Sat, 5 Jan 2008 17:00:47 +0800 (CST)
Dear all,
  Tanks Mayssat for your suggestion. I have set the LINUX_GPIB=YES in the asyn release file.
When I run the application it says GpibBoradDriverConfig not found.
Maybe I didn't load the driver module tnt4882 which my board is
supported. But when I run the gpib_config --minor 0, it says:
[fel@localhost ~]$ su -
Password:
[root@localhost ~]# modprobe tnt4882
[root@localhost ~]# gpib_config --minor 0
failed to bring board online
failed to configure board
main: Operation not permitted
[root@localhost ~]#
What should I do next?
Best wishes
                                                  demin zhang
网 易 有 道 词 典 -- 全 球 最 强 大 的 免 费 英 汉 互 译 词 典 ( 只 有 2 兆 )
Prev: Re: problem in running application of PSM6003 Emmanuel Mayssat
Next: Re: edm troubles John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
