1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics functions application problem
To: ʦê»Àñ <[email protected]>
Cc: [email protected]
Date: Wed, 09 Jan 2008 09:48:56 -0500
FYI : Look at you EPICS base  at src/libCom/osi/devLib.c.
You should use devConnectInterrupt(intVME, SCAN_INT_NUMBER, pFunction, (void*)
&a)
and  devEnableInterruptLevel(intVME, SCAN_INT_LEVEL).
The example file could be found at
http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
under synAppsRTEMS.  The filename is vmeApp/src/drvIK320.c.
Kate
ʦê»Àñ wrote:
> Hi, all
>    I built an epics application, and I used two functions in it like this:
>    #include <devLib.h>
>    static long init(int pass)
>         int a=0;
>         void (*pFunction)();
>         pFunction = scan_record;
>         devConnectInterruptVME(SCAN_INT_NUMBER, pFunction, &a);
>         devEnableInterruptLevelVME(SCAN_INT_LEVEL);
>         return 0;
>    then, I past the compilation, but when I download the object file to the
> target board, and there are the following errors:
>    ld("../bin/RTEMS-mvme5500/power_supply.obj")
>    Unresolved symbol: devConnectInterruptVME
>    Unresolved symbol: devEnableInterruptLevelVME
> any help is appreciated, thanks a lot!
> Haoli Shi
epics functions application problem 师昊礼
Prev: EDM Motif Widget Rendering John Dobbins
Next: Re: VME Toaster - has anyone else experienced this? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: epics functions application problem 师昊礼
Next: VME Toaster - has anyone else experienced this? Gillingham, IJ (Ian)
