1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS-mvme5500 BSP
To: ʦê»Àñ <[email protected]>
Cc: [email protected], [email protected]
Date: Thu, 10 Jan 2008 09:03:05 -0500
As what I have stated previously privately that
there are known bugs  unrelated to your problems, in the version
of the mvme5500 BSP you have that I discourage you from using it,
especially knowing that you are using it for the powerSupply.  This
is all I can say until the EPICS LICENSE issue is resolved between
the  mvme5500 BSP that I wrote and the beatnik BSP that Till
Straumann wrote after  mvme5500 BSP was released.
I can not send you the new kernel until this issue is resolved. I do
not think you can use beatnik leagally at thie point before it's resolved, either.
I will try to answer you the questions below as much as I  can, but
I do not see it as mvme5500 BSP related or  OS related. I recommend
that you  take an EPICS and RTEMS training and have all questions
solved there. I remember  that there is an EPICS workshop/training
to be held in China this Spring.
ʦê»Àñ wrote:
> My EPICS base version is 3.14.6, the same as you use.
> I locate sequencer source codes under base/src/sequence, and then
> modify the file configure/RELEASE(add the following lines)
> EPICS_BASE=/home/rtems/base-3.14.6/base
> TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
> modify the file configure/CONFIG_SITE
> PVCA   = TRUE
> CROSS_COMPILER_TARGET_ARCHS = RTEMS-mvme5500
> and then under the directory /home/rtems/base-3.14.6/base/src/sequence, then make.
> add the line to .cshrc
> set path=(/home/rtems/base-3.14.6/base/sequence/bin/linux-x86 $path)
I did not try sequence with RTEMS yet, but it should not be OS dependent.
Look at the linux-x86.
Obviously, the PATH is wrong if you intended to use RTEMS.  Depending
on the configuration of the Makefile, it should be something like
/home/rtems/base-3.14.6/base/sequence/bin/RTEMS-mvme5500  or
/home/rtems/base-3.14.6/bin/RTEMS-mvme5500  instead of
/home/rtems/base-3.14.6/base/sequence/bin/linux-x86.
Kate
> then add a line to the file /home/rtems/base-3.14.6/base/configure/RELEASE
> SCNSEQ=/home/rtems/base-3.14.6/base/src/sequence
> in my epics application, part of Makefile is as follows:
> ifneq ($(SNCSEQ),)
>     # This builds sncExample as a component of power_supply
>     power_supply_DBD += sncExample.dbd
>     power_supply_SRCS += sncExample.stt
>     power_supply_LIBS += seq pv
>     # The following builds myProgram as a standalone application
>     PROD_HOST += myProgram
>     myProgram_SNCFLAGS += +m
>     myProgram_SRCS += myProgram.st
>     myProgram_LIBS += seq pv
>     myProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
> endif
> power_supply_LIBS += $(EPICS_BASE_IOC_LIBS)
> and then make, an error appears:
> make[1]: *** No rule to make target `myProgram.o', needed by `myProgram'.  Stop.
> Could you give me the latest kernel and try? any colleagues did not install
> snc under EPICS 3.14.X, so it's a problem to me.
> thanks again!
> Haoli Shi
> First, I think the version of the mvme5500 BSP that
> you use have a known bug at run-time, which,
> unfortunately,  I can not discolsed any further until
> I have resolved the issue of the EPICS license violation,
> which was caused by the beatnik BPS that is written
> by Till STraumann of SLAC.
> Thus, I do discourage you from using it with
> the power supply.
> 1) Unresolved symbol: pdevLibVirtualOS
> I do not have this problem.
> Which version of EPICS do you use ?
> 2) SNCSEQ should not have to do with any BSP.
> It depends on how you set the Makefile.
> Kate
Prev: Re: VME Toaster - has anyone else experienced this? Korhonen Timo
Next: VXI11 GPIB and asynRecord Eric Williams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM Motif Widget Rendering John Dobbins
