1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: libgpib: IBOPENDEV ioctl failed
To: [email protected]
Date: Fri, 11 Jan 2008 18:18:47 +0800 (CST)
Dear all,
 I am trying to communicate the gpib device with asyn.when running application,there is no error. But when I use the command dpf,it says:
epics> dbl
PSM6003:PSM6003Record:current
PSM6003:PSM6003Record:current-step
epics> dbpf PSM6003:PSM6003Record:current-step 0.5
DBR_STRING:          0.5
epics> libgpib: IBOPENDEV ioctl failed
libgpib: ibfind failed to get descriptor
2008/01/11 15:30:20.803 L0 addr -1 : EDVR 0: OS error.
2008/01/11 15:30:20.804  151042680 autoConnect could not connect
The gpib_config file is:
interface {
        minor = 0
        board_type = "ni_pci"
        name = "L0"
        pad = 0
        sad = 0
        timeout = T3s
        eos = 0x0a
        set-reos = yes
        set-bin = no
        set-xeos = no
        set-eot = yes
        base = 0x310
        irq  = 7
        dma  = 0
        master = yes
Have a great weekend!
                                      demin zhang
网 易 有 道 词 典 -- 全 球 最 强 大 的 免 费 英 汉 互 译 词 典 ( 只 有 2 兆 )
Re: libgpib: IBOPENDEV ioctl failed Emmanuel Mayssat
Prev: RE: VXI11 GPIB and asynRecord Mark Rivers
Next: Re: libgpib: IBOPENDEV ioctl failed Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VXI11 GPIB and asynRecord Eric Williams
