1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VDCT
To: [email protected]
Date: Tue, 29 Jan 2008 18:58:47 -0600
I am trying to run VDCT version 1271, on FedoraCore5, and have noticed some problems:
when running runScript commend  (notice .vdctplugins.xml missing file?):
SYNTAX: ./runScript {.dbd, .dbd} .db
Loading VisualDCT v2.5 build 1271...
gnu.xml.dom.ls.DomLSException: VisualDCT.jar!/config/.vdctplugins.xml (No such file or directory)
   at gnu.xml.dom.ls.DomLSParser.getInputSource(libgcj.so.7)
   at gnu.xml.dom.ls.DomLSParser.doParse(libgcj.so.7)
   at gnu.xml.dom.ls.DomLSParser.parse(libgcj.so.7)
   at gnu.xml.dom.ls.DomLSParser.parseURI(libgcj.so.7)
   at gnu.xml.dom.DomDocumentBuilder.parse(libgcj.so.7)
   at com.cosylab.vdct.xml.XMLManager.readResourceDocument(Unknown Source)
   at com.cosylab.vdct.plugin.PluginXMLSerializer.importPlugins(Unknown Source)
   at com.cosylab.vdct.plugin.PluginManager.load(Unknown Source)
   at com.cosylab.vdct.plugin.PluginManager.<init>(Unknown Source)
   at com.cosylab.vdct.plugin.PluginManager.getInstance(Unknown Source)
   at com.cosylab.vdct.plugin.export.ExportMenu.init(Unknown Source)
   at com.cosylab.vdct.VisualDCT.getExportMenuItem(Unknown Source)
   at com.cosylab.vdct.VisualDCT.getFileMenu(Unknown Source)
   at com.cosylab.vdct.VisualDCT.getVisualDCTJMenuBar(Unknown Source)
   at com.cosylab.vdct.VisualDCT.initialize(Unknown Source)
   at com.cosylab.vdct.VisualDCT.<init>(Unknown Source)
   at com.cosylab.vdct.VisualDCT$8.run(Unknown Source)
   at java.awt.event.InvocationEvent.dispatch(libgcj.so.7)
   at java.awt.EventQueue.dispatchEvent(libgcj.so.7)
   at java.awt.EventDispatchThread.run(libgcj.so.7)
Caused by: java.io.FileNotFoundException: VisualDCT.jar!/config/.vdctplugins.xml (No such file or directory)
   at gnu.java.nio.channels.FileChannelImpl.open(libgcj.so.7)
   at gnu.java.nio.channels.FileChannelImpl.<init>(libgcj.so.7)
   at java.io.FileInputStream.<init>(libgcj.so.7)
   at gnu.java.net.protocol.file.Connection.connect(libgcj.so.7)
   at gnu.java.net.protocol.file.Connection.getInputStream(libgcj.so.7)
   at java.net.URL.openStream(libgcj.so.7)
   ...19 more
If I just run
./runScript
A GUI "Open" opens up, but I can not select any .dbd files (can not browse directories). If "Open" window is moved, after "Files of Type:" is selected, the "Files of Types:" window does not move with "Open" wondow, but stays in old position.
In either case the VDCT does not run.
Kazimierz Gofron ([email protected]) (630)252-0535
Structure Biology Center
Advanced Photon Source, Argonne National Laboratory
Re: VDCT Matthieu Bec
Prev: Engineer Position at SNS White, Karen S.
Next: Re: VDCT Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
