we are trying to get the portable channel access server (from R3.14.8.2) running on a pure vxWorks system (no EPICS IOC). The first thing I noticed was that several C++ template instances were missing: #include <ipIgnoreEntry.h> #include <casChannelI.h> template class resTable < ipIgnoreEntry, ipIgnoreEntry >; template class resTable < casChannelI, chronIntId >; template class resTable < casEventMaskEntry, stringId >; template class chronIntIdResTable < casChannelI >; template tsFreeList < casMonEvent, 1024, epicsMutexNOOP >; template tsFreeList < casMonitor, 1024, epicsMutex >; template tsFreeList < ipIgnoreEntry, 128, epicsMutex >; There is no templateInstances.cpp file in cas as it is in some other EPICS base libraries. This should probably be added. After adding those instances (which required to #include a few "private" header files which are not installed normally), I got a loadable *.munch library. But the server still seems not to work as under Linux. (It does not reply on caget.) Is there something special to do on vxWorks? Has anyone else ever run cas on vxWorks? Dirk -- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
