1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: several state sets in one stt file
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 22 Feb 2008 23:04:36 -0300
Hi Emmanuel,
I would try seqShow <specific ss>, that gives a little bit more information. I remember having issue when I had inexistent/down channels. Taken from the seq manual:
Connection Management
[..] Normally the state programs are not run until all database channels are connected. However, with the -c compile flag execution begins while the connections are being established [..]
PS to tech-talk administrator: I don't know if it's our mail server or the tech-talk exploder that needs a bit of caring, I saw replies 1 or 2 days after they had been posted. I since deleted them but remember seeing something like 'bounced' in the from field.
Matthieu
Emmanuel Mayssat wrote:
Hello,
I am trying to start a sequencer program with several/independent state
sets. As it turns out the command seqShow reports that 2 threads are
running. But my second thread doesn't appear to be running. For example
seqLog messages do not appear anywhere(console or log file), my PV are
not updated, etc.
Is it possible to have several ss entries in one stt file?
Is there a trick to start/stop a specific state set?
PS: seq-2.0.11
Emmanuel
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
several state sets in one stt file Emmanuel Mayssat
Prev: several state sets in one stt file Emmanuel Mayssat
Next: Re: How to build jca.dll manually rather than to use the ANT build tool? Zhichu Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS 2008 meeting information LIU Songqiang
