1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Minor VLinac compilation problem on OS X 10.5?
To: "Bertrand H.J. Biritz" <[email protected]>
Cc: [email protected]
Date: Wed, 27 Feb 2008 12:04:01 -0500
I don't know about the Virtual Linac, but I added the following lines to the EPICS base file, config/os/CONFIG.darwinCommon.darwinCommon
# X11 and motif paths
MOTIF_LIB = /opt/local/lib
MOTIF_INC = /opt/local/include
X11_LIB = /usr/X11/lib
I needed these lines to build other MOTIF based EPICS applications.
best regards,
tom
On Feb 23, 2008, at 1:56 PM, Bertrand H.J. Biritz wrote:
Dear Tech-Talk,
so I finally got around to installing more of EPICS on my Mac (PowerBook G4, OS X 10.5.2). I came across this error message while trying to compile the Virtual Linac:
make[2]: *** No rule to make target `../../lib/darwin-ppc/libXm. 3.dylib', needed by `build'. Stop.
I checked in MacPorts and OpenMotif provides libXm.4.dylib. When changing the following in the Makefile located in install/App
LIBLIST_Darwin := libXm.3.dylib
to
LIBLIST_Darwin := libXm.4.dylib
I still get an error message.
When commenting out the line the compilation proceeded without any errors. Running the program I didn't come across any obvious problems.
So my question is: did I do something "illegal"?
Bertrand
Minor VLinac compilation problem on OS X 10.5? Bertrand H.J. Biritz
Prev: Problems with edm-1.11.1 on Linux (and OS X) Eric Norum
Next: Problems with edm-1.11.1 on Linux (and OS X) Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Minor VLinac compilation problem on OS X 10.5? Bertrand H.J. Biritz
Next: Re: Minor VLinac compilation problem on OS X 10.5? Eric Norum
