1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Are EDM screens forwards compatible from version 1-10 to 1-11?
To: John Sinclair <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 27 Feb 2008 14:41:40 -0600
On Feb 27, 2008, at 1:31 PM, John Sinclair wrote:
Mark,
Your old screens should be compatible.
As of 1-11-1, the file named edmPvObjects has been changed somewhat and must be repopulated. The easiest way to accomplish this is as follows:
mv edmPvObjects edmPvObjects-old
edm -addpv /somedir/libEpics.so
dm -addpv /somedir/libLoc.so
dm -addpv /somedir/libCalc.so
where /somdir is the location of the referenced sharable libraries.
Sorry for the lack of documentation. I failed to clearly state the requirement to repopulate edmPvObjects.
If this does not fix your problem, let me know.
I see neither libLoc nor libCalc when I build edm-1-11-1. I see only baselib/O.linux-x86/libEdmBase.so
Am I neglecting to build something or building something improperly?
I see a calc_pv_factory in lib/O.darwin-x86/libcfcaa62e-8199-11d3- a77f-00104b8742df.3.14.9.dylib -- is that in place of or in addition to libCalc.so?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Are EDM screens forwards compatible from version 1-10 to 1-11? Mark Bennett
Re: Are EDM screens forwards compatible from version 1-10 to 1-11? John Sinclair
Prev: Tech-talk delivery delays Andrew Johnson
Next: Re: Initialize multi-element field Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Are EDM screens forwards compatible from version 1-10 to 1-11? John Sinclair
Next: compiler options Heinrich du Toit
