1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building MEDM
To: [email protected]
Date: Tue, 11 Mar 2008 10:17:33 -0400
On 3/11/08 9:35 AM, David Dudley wrote:
> Oh, so it's that file.  I was looking for something in base.  I have
> that file, and I have the settings set correctly in it.  However, when I
> get over to the build for MEDM, the variables appear to be blank.  This
> is only happening on MEDM, not on any of the other extensions.
> David
Hi, David.
What version of EPICS base are you using?
Are you using the new "Extensions Top" config files from
  http://www.aps.anl.gov/epics/extensions/configure/index.php
What version of MEDM are you trying to compile?
Could you send the commands you're using to compile MEDM and their output?
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
Re: Building MEDM David Dudley
RE: Building MEDM Hammonds, John P.
RE: Building MEDM David Dudley
Prev: RE: Building MEDM David Dudley
Next: Re: Building MEDM David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
