1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Listen to multiple events
To: "Dehong Zhang" <[email protected]>, <[email protected]>
Date: Mon, 17 Mar 2008 15:00:32 -0700
Hi Dehong,
> Can one EPICS record listen to more than one event?  If yes, how could set it up?
Do you mean can one record be processed on different events?  If that is what you mean, then you could FLNK to the record from both event records.  For instance, if I have 2 EVR event records (for EVR card 0), I could FLNK to the same record from both of them like this:
record(event, "Test:Event1") {
  field(DTYP, "MRF Event Receiver")
  field(INP, "#C0 S1 @")
  field(SCAN, "I/O Intr")
  field(VAL, "1")
  field(FLNK, "Test:RecordToProcessOnEvent1or2")
record(event, "Test:Event2") {
  field(INP, "#C0 S2 @")
  field(VAL, "2")
record(ai, "Test:RecordToProcessOnEvent1or2") {
  field(SCAN, "Passive")
...other ai fields here...
Stephanie Allison
Re: Listen to multiple events Korhonen Timo
Listen to multiple events Dehong Zhang
Prev: Listen to multiple events Dehong Zhang
Next: EDM cursors. Terry Carlino
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Listen to multiple events Korhonen Timo
