1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS: Selecting a Text Error Message
To: [email protected]
Date: Fri, 21 Mar 2008 19:58:21 +0100
On Donnerstag, 20. März 2008, Schoeneburg, Bernd wrote:
> I have created a "strtabRecord" (string Table Record) for exactly this
> problem. It uses an externally loaded string library. The library
> contains the string tables. Each entry consists of the integer number, a
> string and an alarm severirty. If the input number is not defined in the
> table, the record will display the number instead and the alarm severity
> will be set to the predefined (UNSV). You can select a different table
> during runtime. Connecting the library works similar to the subroutine
> record. If you are interested I can send you the sources.
This sound pretty cool. Would it be possible for you to set up a web page
where people can download this (and also add an entry to the EPICS modules
directory)?
Cheers
Ben
EPICS: Selecting a Text Error Message David Dudley
Re: EPICS: Selecting a Text Error Message Schoeneburg, Bernd
Prev: Re: EPICS: Selecting a Text Error Message David Dudley
Next: VME module identification tagging and storage Harms, Michael JJ
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CALC expression feature request Benjamin Franksen
