1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StringIn and StringOut
To: <[email protected]>
Date: Fri, 21 Mar 2008 17:59:36 -0500
The WIKI (I know, its only 3.13, but it's all there is right now)
implies that StringIn and StringOut support soft devices only.
If I write si and so support into my driver, can I read strings using
it?  I need to read an identification string from a PLC, and it is
returned "as a string".  Also, I need to read/write information to a
group of Cutler-Hammer devices, which use IMPACC communications, that is
based on 6 byte strings.  Would be a great advantage if I could directly
access them.
Now that we're actually starting to get serious about EPICS, I've got
people crawling all over the place wanting access to information in the
remotes, and wanting to get trained on EPICS.  Andrew, you really need
to get the guys to fix the website so the softTV training videos are
available.  I get intermittent connection errors when I try to open the
RealVideo streams.  Sometimes it works ...for a while..., sometimes it
doesn't.
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
RE: StringIn and StringOut Mark Rivers
Re: StringIn and StringOut Andrew Johnson
Prev: VME module identification tagging and storage Harms, Michael JJ
Next: RE: StringIn and StringOut Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
