1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM CA Exception Limit
To: "Rodney R. Porter" <[email protected]>
Cc: [email protected]
Date: Thu, 27 Mar 2008 09:01:51 -0700
You may want to look at the -noMsg option of medm.
Are you sure the problem you are having is related to the version OS?
I have several problems with medm (and edm BTW), but in my case it seems
to be related to the version of the epics base I am building against.
My medm (3.1.1+) works when build on epics base 3.4.6 and but not with
3.4.9 ( compile, execute, but never connect to IOC)
Conversely, my edm (1_10_1d+) works when compiled against 3.4.9 but not
with 3.4.6 (doesn't compile easily)
Good luck,
E
On Wed, 2008-03-26 at 17:32 -0500, Rodney R. Porter wrote:
> I get the following error from MEDM on Fedora Core 4, with similar
> unexplained MEDM communication hangs on Fedora Core 6:
> medmCAExceptionHandlerCb:  Channel Access Exception:
> Too many exceptions [25]
> No more will be handled
> Please fix the problem and restart MEDM
> As far as I have been able to tell, the exceptions are generated when an ioc
> is restarted.  Does anyone have any other experience with this error?
> Rodney Porter
> Nanoprobe Beamline
Re: MEDM CA Exception Limit Emmanuel Mayssat
MEDM CA Exception Limit Rodney R. Porter
Prev: MEDM CA Exception Limit Rodney R. Porter
Next: Install StripTool 米清茹
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MEDM CA Exception Limit Emmanuel Mayssat
