1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cross subnet CA communication
Cc: Tech-talk <[email protected]>
Date: Wed, 02 Apr 2008 15:12:15 -0400
Sorry, now there is a typo... I mean to say 129.57.239.255 is the broadcast address....
Sue Witherspoon wrote:
Yes, the 129.57.239.255 is the broad address for the 236 subnet. I have tried using the actual address (129.57.236.20) also but neither seems to open the flood gates of communication.
Any other thoughts?
Thanks in advance,
Sue
Andrew Johnson wrote:
Hi Sue,
I have a curious problem concerning multi-subnet connectivity when converting from Epics 3.13.2 to Epics 3.14.8.2. Using the same network setup and database the 3.13 db can communicate across subnets while the 3.14 db gets a link error.
I'm having difficulty understanding your subnet architecture; the IP addresses you're using don't seem to match up — I think you just have a typo in your EPICS_CA_ADDR_LIST setting.
From your description you have a heartbeat calc record on iocmc1 (129.57.236.20) which you would like to monitor from an ai record on iocfb1 (129.57.230.101). In order for that link to work, the EPICS_CA_ADDR_LIST on iocfb1 must include the 129.57.236.xxx subnet, but you're pointing it to the 129.57.239.xxx subnet instead:
  resource.def file  for iocfb1
      putenv ("EPICS_CA_AUTO_ADDR_LIST = YES")
      putenv ("EPICS_CA_ADDR_LIST = 129.57.239.255")
HTH,
- Andrew
cross subnet CA communication Sue Witherspoon
Re: cross subnet CA communication Andrew Johnson
Re: cross subnet CA communication Sue Witherspoon
Prev: Re: cross subnet CA communication Sue Witherspoon
Next: Re: cross subnet CA communication Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
