1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: genSub and capture monitor event
To: Eric Norum <[email protected]>
Cc: epics <[email protected]>
Date: Thu, 03 Apr 2008 16:58:48 -0700
That's not exactly what I want...
I want to execute something like that:
if PV1 is updated, process gensub and compute new PV2
if PV2 is updated, process gensub and compute new PV1
PV1 and PV2 and both inputs and outputs of gensub
It is the classic loop problem, but with gensub. ;-)
The computed new PV are such that there is a equilibrium (and monitor
are disabled if new value is same as old one (field(mdel,"1"))).
In other words, gensub needs to detect if it is PV1 or PV2 that updated
first, then it update the other.
E
On Thu, 2008-04-03 at 17:56 -0500, Eric Norum wrote:
> You should be able to do this by making the genSub input link a
> channel access link (assuming that the genSub SCAN field is Passive):
> 	field(INPA, "foobar.VAL CP")
> On Apr 3, 2008, at 5:31 PM, Emmanuel Mayssat wrote:
> > Hello,
> > Is there a way to detect a monitor event in a genSub routine?
> > I believe it is possible in the sequencer with the evflag entries.
> > But I am interested in doing that with a genSub record this time.
> > If gensub cannot do it, is it possible to detect a monitor event with
> > any other means than through the sequencer ?
> > Emmanuel
Re: genSub and capture monitor event Eric Norum
genSub and capture monitor event Emmanuel Mayssat
Prev: Re: genSub and capture monitor event Eric Norum
Next: Re: genSub and capture monitor event Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
