1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building motor6-3 record
To: David Morris <[email protected]>
Cc: [email protected]
Date: Fri, 04 Apr 2008 10:46:39 -0500
David Morris wrote:
Hello all
We are trying valiantly but unsuccessfully to build the motor record 6-3 to incorporate the Galil motor driver from ALS (a non-asyn device driver). In trying to build the NoAsyn example of the motor record, we are constantly encountering the requirement to have asyn. We have not yet tried this on a clean install of base, but suspect there may be some debris from our asyn build (used for another project) leaking over into the motor record build. Has anyone experienced this, and found a solution?
Thanks in advance.
In motor record R6-3, motorLib is built with unconditional external references to asyn.
I've recently changed the <motor>/motorApp/MotorSrc/Makefile to conditionally include
asyn dependent code. Updating the Makefile may resolve your problem.
The updated Makefile, which will be in the next release, is attached.
Ron
# Makefile
TOP = ../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# The following are used for debugging messages.
#!USR_CXXFLAGS += -DDEBUG
DBDINC += motorRecord.h
DBD += motorSupport.dbd
INC += motor.h motordevCom.h motordrvCom.h
INC += motordrvComCode.h
ifdef ASYN
INC += asynMotorStatus.h
INC += motor_interface.h
INC += paramLib.h
endif
LIBRARY_IOC += motor
# The following are required for all motor record configurations.
motor_SRCS += motorRecord.cc motordevCom.cc motordrvCom.cc
motor_SRCS += motorUtil.cc motorUtilAux.cc
ifdef ASYN
motor_SRCS += asynMotorStatusBase.c
motor_SRCS += drvMotorAsyn.c
motor_SRCS += devMotorAsyn.c
motor_SRCS += paramLib.c
motor_LIBS += asyn
endif
motor_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
Building motor6-3 record David Morris
Prev: Re: compiling error:expected constructor, destructor, or type conversion before "(" token Stefan Heim
Next: Re: genSub and capture monitor event Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building motor6-3 record Mark Rivers
Next: genSub and capture monitor event Emmanuel Mayssat
