> If I understand correctly the GigE camera comes with a network stack
> that catches/filters the incoming packets.
Yes, that's correct.
< I assume that your GigE camera
> network stack needs to be configured as well.
I don't know of any way to configure it. I think it is automatic, it
knows if a packet is from one of their cameras from the protocol in the
packet header. It appears in the Windows Control Panel/Local Area
Connection Properties/Prosilica GigE Viewer. But it does not allow one
to edit any properties (unlike Internet Protocol on that same list),
one can only enable or disable it.
> Do both of the windows computers you are talking about connect to the
> same camera (same IP address) and use exactly the same
> filtering rules?
Yes.
> -----Original Message-----
> From: Emmanuel Mayssat [mailto:[email protected]]
> Sent: Friday, April 11, 2008 5:50 PM
> To: Mark Rivers
> Cc: Jeff Hill; [email protected]
> Subject: RE: Windows EPICS problem - PROBLEM SOLVED
> Mark,
> VPN software works similarly.
> VPN software needs to be configured to know whether to
> redirect a packet
> over the VPN or not(filtering rule). I assume that your GigE camera
> filtering rules?
> If so, then I am clueless ;-)
> On Fri, 2008-04-11 at 14:37 -0500, Mark Rivers wrote:
> > I figured out the source of the problem, but I don't understand it.
> > I had installed a packet filter from Prosilica for their
> GigE Vision cameras. That filter is intercepts GigE Vision
> packets before they reach the Windows TCP/IP stack for
> efficiency, but passes everything else on. When I just
> uninstalled that packet filter channel access then behaved
> normallly. When I installed it again channel access went
> back to the behavior where I had to add localhost to
> EPICS_CA_ADDR_LIST.
> > What is strange is that on another Windows machine I also
> have the packet filter installed, and channel access works
> fine. That is the computer 164.54.160.38 for which I had also
> included the route print on my last message. The only
> difference I can see is which Ethernet chip set is being used.
> > Anyway, I can work around the problem by adding local host
> to EPICS_CA_ADDR_LIST. The benefits of the packet filter
> outweigh the annoyance.
> > Mark
- RE: Windows EPICS problem - PROBLEM SOLVED Emmanuel Mayssat
Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
<2008>
2025
2026
RE: Windows EPICS problem Mark Rivers
<2008>
2025
2026
