1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: can't build R3.13 extension
To: "William F. Steele" <[email protected]>
Cc: [email protected]
Date: Mon, 14 Apr 2008 06:59:16 -0500
If you change any files in base/configure you need to rebuild everything.
> cd base
> gmake clean uninstall
> gmake
From the 3.14.9 readme:
"Build EPICS base
After configuring the build you should be able to build EPICS base by issuing the following commands in the distribution's root directory (base)
gnumake clean uninstall
gnumake
The command "gnumake clean uninstall" will remove all files and directories generated by a previous build. The command "gnumake" will build and install everything for the configured host and targets.
It is recommended that you do a "gnumake clean uninstall" at the root directory of an EPICS directory structure before each complete rebuild to ensure that all components will be rebuilt."
Geoff
On Apr 14, 2008, at 3:24 AM, William F. Steele wrote:
I tried to follow the instructions in the document "Building EPICS R3.13 extensions with R3.14 base", but the document appears to be out of date. I set the symbol COMPAT_TOOLS_313=YES in base/ configure/CONFIG_SITE as instructed and then tried to do a make in base/config/tools, but that failed as there is no Makefile there. I looked back to the R3.14.5 release (I'm using R3.14.9) and found that in that release, /config/tools does have a Makefile. I copied it into my R3.14.9 release and then did a make, which worked, but that did not help building the R3.13 extension. The problem is that the struct 'oldChannelNotify' is not defined. Presumably, that's what the compatibility mechanism is supposed to do, but it doesn't seem to work.
W. F. Steele
can't build R3.13 extension William F. Steele
Prev: can't build R3.13 extension William F. Steele
Next: TVME200 and IP-Octal 232 Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
