1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: autosave issues
To: "Emmanuel Mayssat" <[email protected]>
Cc: epics <[email protected]>
Date: Wed, 16 Apr 2008 20:30:09 -0500
I don't know about the 8 file limitation.  Tim Mooney may know about that.
pass0 is like setting VAL in the db file.  pass1 is not like a caput, it does not cause the record to process, because it is all still done before iocInit.  It has to do with the timing relative to when links have been established I think.
vxWorks typically has no local disk, and NFS is the preferred file system.  For computer-based IOC you don't need to worry about, you can just save to a local disk.
Sent: Wed 4/16/2008 7:11 PM
To: Mark Rivers
Cc: epics
Mark,
I implemented autosave relatively easily thanks to the documentation.
For the set_passX_restoreFile functions, it says that only 8 files can
be restored at each pass.
This is rather an important limitation if I have a restore file per
device (and not 1 per ioc). Is this limitation still applicable?
Is doing a restore at pass0 equivalent to setting the VAL fields in the
db file? For pass1, is it equivalent to having several caputs on a
running ioc?
Why do they recommend saving vxWorks station over NFS? I assume it is
only because of a storage space limitation. If that is the case, then it
is not applicable for computer-based IOC. Isn't it?
E
On Tue, 2008-04-15 at 21:22 -0500, Mark Rivers wrote:
> The problems are probably less frequent than that.  And a beamline might be 4 IOCs.
> The issues tend to arise during power or network failures when the vxWorks VME IOC is in the middle of saving the file via NFS.
> There are safeguards now in place that make this much less likely.  And there are backup files created by the autosave system that can be recovered from.
> Mark
> ________________________________
> From: [email protected] on behalf of Emmanuel Mayssat
> Sent: Tue 4/15/2008 8:35 PM
> To: epics
> Subject: autosave issues
> Hello again,
> I was looking at autosave record/functions.
> I read that APS is experiencing at least 1 autosave issue per beamline,
> per year. Can anyone expend on that?
> I assume that files are being corrupted or such...
> How could that happen?
> Emmanuel
Re: autosave issues Tim Mooney
autosave issues Emmanuel Mayssat
RE: autosave issues Mark Rivers
RE: autosave issues Emmanuel Mayssat
Prev: RE: autosave issues Emmanuel Mayssat
Next: Re: autosave issues Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
