1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice protocol question
To: tech-talk <[email protected]>
Date: Fri, 18 Apr 2008 10:45:34 -0400
Hello Sheng,
I have a Selective Radiation Meter SR-3000, which has serial interface.
I am trying to get serial set/get with StreamDevice works, the control/set commands works fine, but Query response commands are not working yet.
Here are my protocol file, db, and error messages from IOC:
Protocol:
locktimeout = 5000;
terminator   = CR LF;
replytimeout = 1000;
readtimeout  = 1000;
extrainput   = Ignore;
@init{out " ";}
# set commands here works fine
# but get commands...
fmin_get        { out "F_MIN?;"; in "\13, %f"; }
fmax_get        { out "F_MAX?;"; in "\r, %f"; }
mode_get        { out "MODE?;" ; in "%s" ; }
spectrum_get    { out "SPEC?;" ; separator="\13"; in "spectrum = (%f)";
db:
record(ai, "$(S)_$(SS):$(DEV)$(N):FMIN_Get") {
  field(DESC, FMIN Reading")
#  field(SCAN, "10 second")
  field(DTYP, "stream")
  field(INP, "@srm3000.protocol fmin_get $(PORT) 0")
  field(PREC, "2")
  field(HOPR, "")
  field(LOPR, "")
  field(EGU, "Hz")
record(ai, "$(S)_$(SS):$(DEV)$(N):FMAX_Get") {
  field(DESC, "FMAX Reading")
  field(INP, "@srm3000.protocol fmax_get $(PORT) 0")
  field(PREC, "2")
  field(HOPR, "")
  field(LOPR, "")
  field(EGU, "Hz")
record (waveform, "$(S)_$(SS):$(DEV)$(N):Spectrum_Get")
    field (DTYP, "stream")
    field (INP,  "@srm3000.protocol spectrum_get $(PORT) 0")
    field (FTVL, "DOUBLE")
    field (NELM, "10000")
error message from the IOC:
2008/04/16 16:38:48.572 SCL_HPRF:SRM1:FMAX: Timeout after reading 11 bytes "<0d>900000000;"
2008/04/16 16:38:49.592 SCL_HPRF:SRM1:FMIN: Timeout after reading 11 bytes "<0d>850000000;"
2008/04/16 16:39:10.701 SCL_HPRF:SRM1:ModeGet: Record does not accept input "<0d>SPECTRUM;"
2008/04/16 16:48:08.999 SCL_HPRF:SRM1:Spectrum_Get: Timeout after reading 12702 bytes "...073E-013<0d>1.426E-013;"
2008/04/16 16:48:08.999 StreamBuffer exploded (over 10000 chars). Exiting
Aborted
I tried to skip <od> by
in "CR", "%f";
in "\r", "%f";
in "\13%e;"
but could not be not successful. Does anybody have idea how that <0d> can be ignored/skipped as a beginning in ai/bi or separator in the waveform?
Thanks alot in advance.
Xiaosong
SNS Controls
Re: StreamDevice protocol question Geng, Xiaosong
Prev: edm runtime XtAddCallback errors John M. Skinner
Next: Re: edm runtime XtAddCallback errors - fixed John M. Skinner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: edm runtime XtAddCallback errors - fixed John M. Skinner
Next: Re: StreamDevice protocol question Geng, Xiaosong
